Ok, With the help of you guy's I think I have most if not everything I need. I want to run it by you guy's to see if I'm missing anything before I start installation.
1) Sony MEX-100BT HU
1) SS PN4. 1000D
1) Set of BT 7.1's
1) set of Kicker 41KSC674
1) BT 1005X
1) Boss audio RCA interconnect kit
1) spool of 10 gauge speaker wire. ( I already had)
1) Aluminum amp mounting bracket
Is the stock speaker wire running to the rear side pods sufficient or do you suggest a better speaker wire?
