Series/Parallel Wiring
Old Nov 13, 2015 | 02:23 PM
Aero993's Avatar
Aero993
Question Series/Parallel Wiring
Hello,
I was looking on the internet at speaker wiring diagrams. I found a diagram where they had wired 4 2-ohm speakers using the Series/Parallel method. This method didn't change the total impedance to the amp. Even though they had
4 2-ohm speakers, the amp saw a 2-ohm load. Are there any disadvantages of wiring speakers using this method?
Old Nov 13, 2015 | 02:35 PM
haze324's Avatar
haze324
I guess in theory you could wire two sets of 2ohm speakers in series and then wire it with another two sets in a parallel.
The downside I'd imagine is splitting the output 4 ways doesn't leave much juice to each speaker.
Can you post the diagram or a link to it.
Old Nov 13, 2015 | 02:41 PM
Aero993's Avatar
Aero993
http://nationalautosound.com/subwoofer-wiring-diagrams/
Scroll down to the third diagram. Would it be lower since it still pushing 2-ohms? idk
Old Nov 13, 2015 | 02:46 PM
haze324's Avatar
haze324
The output to your speaker is lower because you're dividing by 4. Running 4ohm speaker in parallel is 2 speakers splitting a 2ohm load output. So lets say that's a PN4.1000d you are splitting 220w @2ohm into two speakers. This way you are splitting that same output in 4 --- each speaker gets much less.
marcodarq
Audio Systems
Jul 21, 2018 02:26 PM
Nickblink
Audio Systems
13
Jul 22, 2014 07:52 PM
Fantozi
Audio Systems
42
Jun 27, 2014 12:53 PM
vbouncer
Audio Systems
Mar 18, 2014 03:58 PM
Mongo40
Aug 13, 2008 04:54 PM
