Install prep question
Old Nov 18, 2015 | 06:22 PM
SBates08's Avatar
SBates08
Originally Posted by timbo141
On a bike with security you need to turn ignition on, then off, and disconnect the battery (or pull the maxi-fuse) BEFORE the system arms itself. If you disconnect the battery when security is armed, you guessed it you will get a piercing earfull...
This only applies if you have the alarm. Having security doesn't necessarily mean you have the audible alarm.
2010 Limited with some stuff
Old Nov 18, 2015 | 08:16 PM
timbo141's Avatar
timbo141
Good catch. If you don't have the smart siren you just get the blinking lights
Old Nov 19, 2015 | 12:24 PM
nineball's Avatar
nineball
is this something year-specific? on my 06 ultra i have disconnected and reconnected the battery several times (run/brake/turn install, fi2000 install, audio install, daymaker install, etc) and never had a problem with the alarm system, no on/off or anything else done any time.
Old Nov 19, 2015 | 12:33 PM
SBates08's Avatar
SBates08
The only problem you'll have with the security system is the smart siren. Mine doesn't have it so it's never been an issue. I've never noticed my blinkers flashing either.
Old Nov 19, 2015 | 02:51 PM
nineball's Avatar
nineball
i have no clue what a smart siren is, so mine may be smart or dumb at this point. I know it does work though via testing.
Old Nov 19, 2015 | 03:06 PM
SBates08's Avatar
SBates08
Hahaha I hear ya. The smart siren is the add on audible part of the security system.
Old Nov 19, 2015 | 03:41 PM
nineball's Avatar
nineball
i guess i'll just chalk my experiences up to being lucky since i've never had a problem. thanks for the info.
Old Nov 19, 2015 | 05:20 PM
timbo141's Avatar
timbo141
I believe the security went to auto arming/ disarming in 2007.
Does your fob have a button you press to arm and disarm?
2007 the fobs didn't have any buttons, they automatically armed the bike after five seconds or so. Then when movement was detected the alarm would "look" for the fob, if present it would disarm, if not it would go off.
So if your 2006 wasn't armed you could disconnect the battery and nothing would happen.
Old Nov 20, 2015 | 12:16 PM
nineball's Avatar
nineball
that makes sense. my 06 ultra has the button on the fob. i guess i do have a dumb siren after all
Old Nov 21, 2015 | 05:39 AM
JimTJr's Avatar
JimTJr
How do you get the blinking lights without a battery?
On looking at my service manual, it says on page 1-55 to "Disarm security" in one of the steps for battery removal/disconnect. I suppose there could be problems with the security module after if you do it while armed.
Did you get it installed yet GOLFINDS? Comeon man, I want to hear about it!
