Amp install
Based on the speakers I'm guessing the consensus is an amp at least 75 watts up?
So what's the best reecomendation? I may or may not need to find a new place to mount the bt line levelers and crossovers for my speakers. Which was a plus for the memphis amp with its size
Note* One tip on the gains. You always want to set your gains low as possible to get good sound. The stronger the signal on your HU and the higher the sensitivity on your speakers the lower you can set the gains. High gains more often than not cause distortion.
2010 Limited with some stuff
http://www.sonicelectronix.com/item_...FVAJkQod7twNog
http://www.sonicelectronix.com/item_...74-KSC674.html
I should have mentioned I have the bt line levelers that are integrated into their breakout harness since the rushmore have different rear hookups. I do like the sound I have now in the hertz and if I do change them would probably go with another component speaker. Which for the rears will be interesting to figure out.
i respectfully disagree
not even sonic can compete with crutchfield when it comes to customer service. on more than one occasion they have over-nighted me a replacement WITH the return shipping label, and we are not talking about $100 items here. most retailers, including sonic i believe, require you to send back yours before they send out a new one and/or a refund. plus the guys who answer the phone at crutchfield are pretty damn good.the flip side is that crutchfield typically is higher priced than any other retailer, but they are an authorized vendor for EVERYTHING they sell, so there will never be any warranty issues. not many sites can make that claim.
