Thoughts on this setup
Old Dec 7, 2015 | 04:59 PM
Gannicus's Avatar
Gannicus
Originally Posted by SBates08
Even with that knowledge of the RZ4 I would still lean towards the pn4.1000D. I have the 4.520 which is the same amp as the RZ4 and I know what the Kappas sound like on that amp. I also know what they sound like when you have more power to throw at them too. I think the 4.1000D would be a better amp for the BT's and Kappas as well to see their full potential.
2010 Limited with some stuff
Agreed.
Old Dec 7, 2015 | 08:21 PM
BlackPearl#1's Avatar
BlackPearl#1
I run BT 7.1s in the fairing driven by the RZ4 and love it. My other 2 channels run lower titan 6.5s and it is awesome.
Kris
Old Jan 18, 2016 | 03:25 PM
fl1996nos's Avatar
fl1996nos
Soooo. Decided to go with the advice given and picked up a SS PN4.1000D to go with my 7.1's/fairing and kappas/lowers. Plan on installing them this week. Going to set gains with 1khz test tone and DMM. What do I set crossover to and at what Hz.
Old Jan 18, 2016 | 03:45 PM
haze324's Avatar
haze324
You have the stock HU?
Try the lowest setting of 40hz on the HPF and see how it sounds. I'd say no higher than 60ish. Those speakers can produce a decent bass.
Old Jan 18, 2016 | 03:49 PM
fl1996nos's Avatar
fl1996nos
Thanks Haze, yes HK HU. Will try that.
Old Jan 18, 2016 | 03:51 PM
fl1996nos's Avatar
fl1996nos
Do I set the gains at that crossover setting or set gains and then set crossover?
Old Jan 18, 2016 | 03:55 PM
haze324's Avatar
haze324
Set the gain, then the crossover.
Old Jan 18, 2016 | 03:58 PM
fl1996nos's Avatar
fl1996nos
Thanks Haze.
Old Jan 18, 2016 | 04:04 PM
SBates08's Avatar
SBates08
I'm willing to bet you it won't be long before you pull that stock HU for something more versatile.
Old Jan 18, 2016 | 04:08 PM
Gannicus's Avatar
Gannicus
With the 1000D set the gains at 12:00 o'clock straight up. Then set the crossover on HP. At that point you can set the dial to the range HAZE explained in his post. With the Gain setting at 12 you won't get any distortion with the 7.1's.
