Amp & Speaker Relationship
Old Apr 1, 2016 | 09:19 PM
  #51
SBates08's Avatar
SBates08
Just like me to pick the highest priced one. I can't play this no more.
Old Apr 1, 2016 | 10:25 PM
  #52
Tailwind's Avatar
Tailwind
I'd does make u wonder how in the hell can the core specs be within an RCH of some of the others yet be 400 to 500 bucks more.
That's the shix Haze is talking about regarding the deep dive specs / eye charts, not to mention the fact that when u hit a certain audio level the speakers are hand made by engineers versus Chinese machines. Now that shix should be in the specs.
You did pick a winner though!!!!!
I do take all major CCs so no worries!!!!
T.
Old Apr 1, 2016 | 10:47 PM
  #53
SBates08's Avatar
SBates08
After a 107 BB kit today I'm tapped. It does however put some things into a little better perspective though.
Old Apr 2, 2016 | 05:42 PM
  #54
slyedog's Avatar
slyedog
T.
I think the numbers got mixed up. #1 should have been the Polks viewing from top going across then bottom. I'll post some new specs and lets see what the consensus is?
Old Apr 2, 2016 | 05:59 PM
  #55
slyedog's Avatar
slyedog
Data table
Power Handling - Peak W 300 Power Handling - Continuous W 150 Impedance4 Frequency response Hz 40 Sensitivity dB SPL 91 Voice coil Ř mm (in.) Woofer 36 (1.4) Tweeter 28 (1.1) Woofer size mm (in.) 165 (6.5) Tweeter size mm (in.) 35 (1.38) Woofer magnet Ferrite Tweeter magnet Neodymium Woofer cone Pressed-pulp cone with cotton fibres Tweeter dome Tetolon Crossover type 2 Way Passive Crossover Crossover cut off 3.5 kHz - 12 dB Oct
Continuous Output Power 4 ohm 70w x 4
Continuous Output Power 2 ohm 100w x 4
Continuous Output Power 8 ohm 140w x 2
Continuous Output Power 4 ohm 200w x 2
Minimum Speaker impedance 22 ohm
Frequency Response -3dB 10Hz-30KHz
Input Sensitivity 0.25-8.3v
Input Impedance at 2KHz Unbalanced 14K Ohm
Input Impedance at 2KHz Balanced 7K Ohm
Noise below rated output (30KHz lim) 93dB
Channel Separation at 2KHz >65dB
Damping Factor at 20Hz 4 ohm load >75
Total Harmonic Distortion 4 ohm loads <0.2%
Phase Response at 20KHz Lagging 14 degrees
Slew rate 14
Low Pass Crossover 12dB/octave 45Hz-3.1KHz
High Pass Crossover 12dB/octave 45Hz-3.1KHz
Protection DC, Short Circuit and Thermal Yes
Power Source 10-14.4v DC Yes
Average current consumption with
Program material with 4 ohm loads 9A
Fuse rating 25A
Size W x H (243x41.8mm)/9”x1.64” Yes
Size D (135mm)/5.3” Yes
Shipping Weight (Kg/Lbs) 1.4/3
Old Apr 2, 2016 | 10:45 PM
  #56
Tailwind's Avatar
Tailwind
[quote=slyedog]Data table
Power Handling - Peak W 300 Power Handling - Continuous W 150 Impedance4 Frequency response Hz 40 Sensitivity dB SPL 91 Voice coil Ø mm (in.) Woofer 36 (1.4) Tweeter 28 (1.1) Woofer size mm (in.) 165 (6.5) Tweeter size mm (in.) 35 (1.38) Woofer magnet Ferrite Tweeter magnet Neodymium Woofer cone Pressed-pulp cone with cotton fibres Tweeter dome Tetolon Crossover type 2 Way Passive Crossover Crossover cut off [B]3.5 kHz - 12 dB Oct
Warbird40
Audio Systems
Oct 4, 2015 07:28 AM
shakak
Audio Systems
Nov 22, 2013 05:22 PM
ronherman
Audio Systems
20
Jul 21, 2013 09:43 AM
slip944
Jun 30, 2012 10:50 PM
dgb
Mar 22, 2012 06:44 PM
