Boom Stage 1 Speaker Without Amp
Old Apr 8, 2016 | 06:43 PM
HardRider1's Avatar
HardRider1
Default Boom Stage 1 Speaker Without Amp
Looking for input, wondering how much improvement in sound quality would I see if you mount Stage 1 speakers without an amp?
Old Apr 8, 2016 | 06:47 PM
haze324's Avatar
haze324
1. The Boom stuff isn't that good to begin with, and very overpriced for what they offer
2. To really notice an upgrade while on the road you need an amp
3. For not much you could do speaker and amp that would be worth the upgrade
Old Apr 8, 2016 | 07:00 PM
HardRider1's Avatar
HardRider1
The reason I ask, a gentleman I work with mentioned that he changed out his speakers on a new FLHX and reported improved sound quality, and the speaker covers are much nicer to boot.
Old Apr 8, 2016 | 07:31 PM
dugan's Avatar
dugan
Don't waste your hard earned dollars on those Boom speakers. Not a substantial difference between stock and the Booms w/ built-in tweeters. I have just a little over $300 in Infinity Kappa speakers and a Rockford Fosgate amp. Not the top of the line setup but a helluva lot better than Boom. Strictly my opinion but I suspect others will agree.
Old Apr 8, 2016 | 07:48 PM
HardRider1's Avatar
HardRider1
I have read many times that the Boom audio components are grossly overpriced, I have a few questions regarding adding an aftermarket system, I know there are some very knowledgeable gents on this forum.
How is the amp switched? does the stock boom head unit have a switching connection?
I presume that power for a new amp would have to be wired directly to the battery on a new fused line.
I assume that the existing cabling to the stock speakers may be reused?
Does an added aftermarket amp require a reflash via digital tech?
How is an aftermarket amp mounted? are there Harley specific mounting brackets?
I presume the outputs of the stock head unit become the inputs to the aftermarket amp?
I would prefer a single (4) channel amp to drive (4) speakers.
At what wattage output does one have to consider the bike charging system, something I definitely do not want to get into.
I am sure that I will have more questions but here is a good start, if I were to set a budget it would be in the $800 range, thanks all for your input and suggestions.
Old Apr 8, 2016 | 08:20 PM
Covert Olds's Avatar
Covert Olds
How is the amp switched? does the stock boom head unit have a switching connection? Some use the 12 volt outlet in the right pod or there is a small two wire harness on the left side with switched power.
I presume that power for a new amp would have to be wired directly to the battery on a new fused line. Along with a ground, that is the best way.
I assume that the existing cabling to the stock speakers may be reused? See answer on next question.
Does an added aftermarket amp require a reflash via digital tech? Best way for this is to use a Biketronics BT355 line level converter which uses stock high level outputs-speaker leads-and converts it to low level outputs.
How is an aftermarket amp mounted? are there Harley specific mounting brackets? Depending on the amp, their is a perfect place right on top of the stereo.
I presume the outputs of the stock head unit become the inputs to the aftermarket amp? See above answer.
At what wattage output does one have to consider the bike charging system, something I definitely do not want to get into. That's going to depend on just how crazy you get. Most of the time, nothing is needed.
My answers are in bold.
Old Apr 8, 2016 | 08:31 PM
onedae's Avatar
onedae
I had the Boom speaker only upgrade on a 14 Streetglide and it sucked. Took them out and went back to stock. I know everyone here likes to dump on Hogtunes - BUT - I installed just their speakers, no amp, and left everything else stock and the sound is a lot better. Its definitely not at the level of a full upgrade with an amp, but noticeably better than stock. And pretty cheap - about $150 or so.
Old Apr 8, 2016 | 09:14 PM
HardRider1's Avatar
HardRider1
Thanks for the input, that Biketronics has what looks like some real nice equipment. I have read sometime ago that they run special for the forum members, wonder if there is anything like that going on now or in the near future. Looks like their setup of the 2014's and up are currently out of stock. Any comments on their speaker combinations? What would be best for front fairing and back pods?
Old Apr 9, 2016 | 11:32 AM
CallMeJus's Avatar
CallMeJus
Use the code HDFORUM when you checkout
Old Apr 9, 2016 | 11:55 AM
Greatsteaks's Avatar
Greatsteaks
If you want to use BT speakers in the rear pods you will need spacers for their 6.5's, 7.1's won't fit.
