new sony head unit problems
Old May 14, 2016 | 03:11 AM
scottma978's Avatar
scottma978
after speaking to Biketronics yesterday, the guy told me to definitely run a new ground from the triple tree to the HU. He also said a VERY common problem with the Harleys is at the handlebar controls...he said to loosen, not remove the two halves of the control bases where they clamp onto the bars and make sure the wires are in the grooves....he said many times they are not and wires get pinched and that pinching can cause the same issue I am having. If that fails he told me my old Biketronics unit is under warranty and for 15 bucks they will replace it....for an extra 50 bucks they will give me the ewer updated model that is a much more stable unit in bad ground situations....however they do that..
Old May 14, 2016 | 03:49 AM
myram's Avatar
myram
i just got the same sony head unit will do the install today with the biketroncis retro kit.I was told that kit is the best for flawless operation of the handlebar controls. i hope i don't havr any issues with my sony.
Old May 14, 2016 | 12:57 PM
scottma978's Avatar
scottma978
i just got mine straightened out....i grounded the HU to the chassis...made zero difference. kept farting around with it...double and triple checking all my connections. The night I was installing it, it was near dusk and the mayflies were killing me...I used the same switched lead as I had used on my previous HU (and the power to my amp is straight from the battery on a fused dedicated line). After a little investigating with my test light i found that the switched power lead was acting up. I disconnected it and found an accessory lead, hooked onto that and just like magic...everything seems good.
Old May 14, 2016 | 09:20 PM
slyedog's Avatar
slyedog
The cigarette lighter is good one for that. Good you got it diagnosed. Now you need to do same test before and after the BT module to rule out any issues on bike wiring? Could be anything from a corroded fuse to a pinched or broken wire if before the BT module.
Old May 15, 2016 | 08:57 AM
myram's Avatar
myram
yes i was going to that that too. i used the cigarette lighter for my acc. switched line. I just finished my install. I just have to set the gains and put it all back.I will post a pic when done.
scottma978
Audio Systems
May 12, 2016 09:50 PM
Cool Poppa
2014-2024 Touring Models
Jun 19, 2015 01:01 PM
UltraDune
Audio Systems
Mar 25, 2015 04:45 PM
LOTL
Touring Parts
Dec 15, 2014 01:27 PM
Wheatfield-ez
Audio Systems
Oct 29, 2014 03:26 PM
