Need antenna moved
Old May 15, 2016 | 06:03 AM
davidw221's Avatar
davidw221
Default Need antenna moved
Ok Boyz, I have a shortie antenna in my filler panel on my Streetglide, I'm replacing the filler panel, and going to have lights in it, I won't have enough room to have my antenna there, so I'm going to have a hidden antenna, I've had the phony one in my old bike, (Hogtune), but that was 6 years ago, is there any good antenna's on the market that will serve my needs?
Old May 15, 2016 | 06:56 AM
JimTJr's Avatar
JimTJr
This is pretty cool where the guy took his factory one and did something with the bracket, rotated so it's pointed forward, instead of rearward and bent just a smidge. Then the stock antenna goes up the left side of the bike through the frame, under side cover and stops under the seat. Completely invisible, and still the longer one, which may or may not have better reception.
Old May 15, 2016 | 11:29 AM
Gooey2's Avatar
Gooey2
I did something similar but put it under the side cover, can't see it.
Old May 15, 2016 | 12:32 PM
billablehours's Avatar
billablehours
I did something similar as well. Much less complicated and totally hidden. Just look at the bracket, rotate it and you will get the idea. Easy, free and as good as any aftermarket antenna.
Jersey Drew
Audio Systems
11
Feb 22, 2020 08:55 PM
Recon
2014-2024 Touring Models
11
Mar 16, 2016 04:14 PM
DeneFXDWG
Audio Systems
Sep 3, 2015 07:20 AM
gedo76
Aug 8, 2011 02:02 PM
FLoTR
Nov 13, 2008 04:53 PM
