Focal KRC165 K2 tweeter crossover setting?
Old Jul 27, 2016 | 03:25 PM
Bertk's Avatar
Bertk
Originally Posted by billablehours
Well of course Bert, being the dumb you know what that I am and thinking I can make it better I played with it when I got it. I have tried to reset it to where photos have been provided on the forum showing the settings but I imagine I should have just left well enough alone. I even gave some thought to just getting another one from BT and not messing with it. ha ha. Thanks again for your help
The HPF adjustments on the LL are very sensitive and don't always line up with marks on the label. They can adjust them back close to default using the a DMM.
First you will want to line them up with the default marks.
You will need a test tone to balance them. The 315Hz 0db will work. You will find one in this download.
The VAC measurements using the DMM will be taken from the RCA outputs at the LL.
Disconnect the RCA's from the LL.
Connect the positive lead from the DMM to the center of the RCA plug and the negative to the outside. See pics.
Using the 315Hz test tone set the volume on the HU to 15 and adjust the VAC on each RCA plug so they are balanced and very close to default or a hair under. The VAC should be around 1.0 volts. Let me know what you find.
One of the side effects of adjusting the HPF on the LL is that it also changes the VAC at the speaker outputs on the amp.
So while you have the equipment out you can reset the gains at the speaker outputs on the amp.
Using a 1000Hz -5dB test tone at volume 15 on the HU. Using the DMM set the VAC to 24.50 volts on both channels.
Attached Thumbnails Focal KRC165 K2 tweeter crossover setting?-rca1.jpg   Focal KRC165 K2 tweeter crossover setting?-rca2.jpg
bzmannn
Audio Systems
Apr 15, 2019 08:54 PM
bzmannn
Audio Systems
Oct 15, 2018 07:33 AM
cfave
Audio Systems
Apr 11, 2018 12:21 PM
cash64
Audio Systems
14
Sep 23, 2016 03:28 PM
kryingame
Audio Systems
May 22, 2014 02:37 PM
