Vibration coming from speakers
Old Jul 6, 2016 | 02:18 PM
Briguy1's Avatar
Briguy1
Default Vibration coming from speakers
I have the biketronics 7.1 value line speakers with the biketronics brackets in the fairing. Im noticing some vibration/popping coming from one of the speakers. I have the stock head unit along with Razor RZ4-2000D amp. I also have kicker's KS series in the lowers. How can I tell if I have a blown speaker?
Thanks,
Brian
Old Jul 6, 2016 | 04:14 PM
Bertk's Avatar
Bertk
Thanks,
Brian
First you will want to isolate the speaker(s) making vibration/popping sound.
Then start looking at wiring connections and for correct polarity.
Assuming this is a Rushmore model is there a BT Line Leveler installed? If so check to make sure the LL's setting are set to default and the RCA cables are firmly in place.
How were the gains set on the amp?
Old Jul 6, 2016 | 05:21 PM
Briguy1's Avatar
Briguy1
Yes it is a 15. Used the BT line levers. In the process of taking fairing off. I used the set the gains by ear directions on website. Will probably reset. Can't not figure out what is the flat setting on the stock head unit. I was thinking that it is in the middle where the small circle is between all the bars. Is this correct?
Thanks,
Brian
Old Jul 6, 2016 | 06:56 PM
Bertk's Avatar
Bertk
Thanks,
Brian
This is what I consider flat.
Attached Thumbnails Vibration coming from speakers-flat1.jpg   Vibration coming from speakers-flat2.jpg
Old Jul 6, 2016 | 09:17 PM
Briguy1's Avatar
Briguy1
Reset the gains, tighten a speaker screws up, and added poly fill. It did the trick. Will add poly fill to lowers in the morning.
Thanks All,
Brian
Old Jul 6, 2016 | 11:11 PM
Bertk's Avatar
Bertk
Thanks All,
Brian
Good to see you figured it out.
You will want to leave the AVC or Speed Volume set to OFF.
Quickrunner1
Audio Systems
Mar 31, 2019 07:23 PM
Bafflingbs
Audio Systems
84
Apr 18, 2017 11:29 PM
AlBaron
Audio Systems
11
Jun 23, 2014 09:15 PM
AlBaron
Audio Systems
Jun 9, 2014 10:08 PM
BadPiggy
Feb 25, 2011 03:48 PM
