Ok so the amp is wired up correctly and now it's turning on and then immediately shutting off I've checked every connection from the saddlebags to the battery I've checked the fuses also do you guys know what might be the problem? Just when I thought I would hear my saddlebags come alive NOTHING
Check all the connections on your remote wire. I'm going to assume your powering more than 1 amp using the same remote. If all connections are good you may need to try a different power source (orange and white wire from headlight) to power up the rear amp.
It's actually shutting all the way off and then when I turn it off the ignition to see if will come on it does nothing! I'm lost gentleman.... and your right I'm running two amps but what's weird is my diamond amp and hertz setup is working as usual Thanks for any help
Are you powering both amps on from the same remote feed? This is usually not a problem but it would be the first thing I checked. Find a different remote feed for the PPI amp.
