Plug and Play Audio
Disclaimer: I had the same mandate when I first showed up looking for audio.
What does "plug and play audio system" actually mean?
Is it the entire system that makes it plug and play?
Is it just the amp, HU, and hand control interfaces / harnesses?
What are the benefits of complete plug and play systems that companies use as marketing leverage.
Do BT Lines Levers constitute plug and play?
Are there wiring kits that make any combination of components plug and play?
Just seeing far to many guys that are following my initial footsteps and locked in on the potential misconception of what plug and play actually is and how to manage purchases and installs with the most bang for the buck.
My JM system was plug and play but lasted a very short while.
My HT speaker lids also had some nice plugs but lasted a week.
BT is a very good reliable amp that happens to be plug and play.
My current system, after far too many speakers and amps to count, still just plugs right in.
I'm thinking that plug and play for me meant that I was not going to cut into wires within the HD electrical system on a brand new sled that would void the warranty on such system. The second part of plug and play meant that I was a total dumb shix regarding audio however was not too challenged with plugging harnesses in.
Point of this thread being to help to new guys manage expectations and obtain the perfect install tools so that they to not fall victim to the marketing of complete "systems" that fall well short of reasonable standards, but win us over based on the claim that the install can be accomplished by a cave man.
Thoughts? Comments? Advise?
T.
I'm curious on a cost ananlysis. Cost of a plug and play system vs having a system installed by some on. What's the cost difference and how do you value if one sounds better than the other. Either way, agreed.....in large part PnP is mostly marketing.
To Haze's question, I was looking at two different plug and play systems before finally settling on the BT. I even checked out my local audio shop. The BT system retails for around $900, the RF system for about $1000 and the Boom system, we'll honestly I never considered the Boom Stage 2. My local shop quoted me $950 installed for a Diamond amp, line levelers, and two Focals in the fairing. So if people are going "plug and play" just to avoid the install it seems like you could easily get a better quality system installed by a shop and still pay less than some of the heavily marketed Plug and play systems out there.
I'm thinking the best thing folks that show up here and new to sled audio, the absolute first thing I would do is understand that u can indeed purchase the "plug and play" wiring goods necessary to get good sound to an amp and power to an amp. EG, Rushmore gets BT Line Leveler(s) or comparable and also sled audio power and ground kit with fuse.
From that point I think you will be able to make damn good decisions regarding the remaining ingredients (amp, speaks, etc) that will deliver the sound u desire at a responsible budget.
Not trying to steer anyone towards specific products here, just trying to help guys understand that "plug and play" can be very misleading so no need to dive into certain packages that will not deliver. On the flip side there are some shops / businesses that will provide you killer set up that use proven products with all the wiring kits included.
Just don't fall for this overpriced high energy marketing stuff that many of us have fallen for and regretted. The guys on this forum will not let u down throughout the entire process. Invaluable resource!!!!
T.
However, Tailwind you have made me re-think what that statement really means. Looking at it that way, I can see where some of the people that are new to the installation of aftermarket stereo equipment on their bikes might assume that "Plug and Play" means that all they have to do is remove the faring and all the connections needed for their install will be in the faring and that their new "Kit" will provide all necessary connections to hookup their new equipment....Would that it could, but there a lil more to it than that
Good write-up Tailwind
I'm curious on a cost analysis. Cost of a plug and play system vs having a system installed by some on. What's the cost difference and how do you value if one sounds better than the other. Either way, agreed.....in large part PnP is mostly marketing.
One HUGE thing people don't get is the tune. Installing is easy, the hardest part of any of my installs has been tuning. The most intimidating was taking off the tank (yeah I know, but it was
) and once you've done it once you realize how truely trivial it is. Tuning on the other hand has been something I've had to learn the hard way and it's cost me a lot of money.If I could roll back time (hum along if you know the words), I'd contact a reputable installer with my expectations and see what they can come up with. If it was out of my budget, I'd get something that I could build on (per the installers recommendation). MOST of all though, I'd have THEM install and tune it.
I can't tell you how much money I've spent in the last year trying to chase what I thought I wanted only to find out a few twists of a screwdriver and some precised EQ adjustments could have put me where I want to be a LONG time ago.
Having said all that, I don't regret my path. Like I said, having someone else do it from the start would have been WAY lighter on the wallet though but now I do have the ultimate set of tools (yeah more pop culture references)
I was perfectly happy with my Bt setup , That was no way plug and play, but tank off and power wires was no big deal pods out amp tray was fun project lasted me two years then it was this site that caused me to search out for better, better, better, two steps forward and one back agree with bunker in that someone else to tune it but would still install my self if something quiet's working I have the knowledge to hopefully chase problem down .
Stereo on bike has been pain in butt bike's just not meant to be sound friendly at speed .Most things I work on I have solid game plan with sold outcome on first try know what its going to cost and execute. Bike has kicked my butt and willing to admit it to myself and others.
I feel I am so close but still not where I have set the bar and not sure what its going to cost or take to get there . ALL that said have had fun and like bunker no regret's some day I will be able to laugh at myself as others already have about this bike audio love hate relationship .
To the rest of you just starting down this road pick your target wisely set goals reasonably and Happy Thanksgiving!! to All
When they design a system where wire strippers are not used. That's when I'll call it plug and play. I guarantee there's not one guy who has put in his own system that didn't use wire strippers to do it! JMHO.
My thoughts on PNP are also marketing based. Thanks for the great write up T.
Kris
