Lowers and speaker pods
Old Nov 24, 2016 | 03:15 PM
pdevore's Avatar
pdevore
Default Lowers and speaker pods
Guys,
Im getting ready to order lowers for my 15 RG, I want to make sure this is all I am going to need.
I currently do not have anything for this and in the end I want to be able to install a set of 6.5". I will be having everything custom painted to match the bike so no need for prepainted units. Is there a set of Pods that are primed only?
Again, this is for a RG.
Thanks All
Pete
Unpainted Vented Fairing Lower Kit - 57100258 57100258
$366.00 $366.00
Weight: 65.0 lb
Color-Matched Boom! Fairing Lower Speaker Box-76000497DH 76000497DH
$228.00 $228.00
Extended Warranty: No, thank you Weight: 100.0 lb
Old Nov 29, 2016 | 11:49 PM
Bertk's Avatar
Bertk
Originally Posted by pdevore
Guys,
$366.00 $366.00
Weight: 65.0 lb
$228.00 $228.00
Here are the parts needed for adding speaker boxes the 2014+ model lower fairings, NON WATER COOLED.
Prices are from Boardtracker HD
Vivid Black speaker boxes PN: 76000497DH $280
Speaker Enclosure left & right PN: 76000368/76000369 $41 each
Captive nut (8) PN: 10100064
CVO speaker grills PN: 76000065 $31 each
Grill screws PN: 10200105 (10) $4.80
Gasket seal, adhesive-backed (2) PN: 25700311
If these gaskets are not available 3M double sided can be used and can be found at Autozone or other auto parts stores.
billablehours has done this before.
Boom! Audio fairing lower speaker kit Instructions and another set of Instructions.
Or you can go with one piece speaker boxes from eBay for well under $100, without grills. It appears some mounting hardware may be needed also.
Old Nov 30, 2016 | 02:41 AM
haze324's Avatar
haze324
Do you want lowers? Or is this so you can add more speakers and have a louder bike?
Old Nov 30, 2016 | 02:50 PM
pdevore's Avatar
pdevore
Default Damn you Haze...
Well it's a bit of both, but now I'm in a bit of a spot. I've been researching the crap out of my motor work too and. Ow I'm finding out that I can't run lowers with my SE breather. I mean it's not super critical that I run this air breather but I really like it and I already own it. So now I'm considering just going without the lowers.
I dint nessecarily love the looks of lowers but I've ridden an ultra with them and like the protection. But I don't know if it's enough for me to give up the breather.
I know you(Haze) with in the next month or 2 will be able to give me louder and clearer sound with just the 4 speaker locations (or adding another set to the bags)than I could achieve on my own with adding lower. Hence the reason I haven't done any audio work.
Yes Haze, I'm chomping at the bit to get the killer audio along with my new 107" build.
Thanks
Pefe
Old Nov 30, 2016 | 08:37 PM
haze324's Avatar
haze324
I'll send you a PM in a bit brotha.
Sarge4
Jun 20, 2020 05:44 PM
Scooby1426
Audio Systems
May 23, 2019 08:57 AM
cash64
Audio Systems
14
Sep 23, 2016 03:28 PM
jmcdermit
Audio Systems
32
Oct 10, 2014 05:48 AM
kryingame
Jan 30, 2014 09:20 AM
