lower speakers
Old Feb 4, 2017 | 09:02 AM
Bushy's Avatar
Bushy
Default lower speakers
wondering if anyone knows for sure, buddy has a 17 limited with tour pack removed, therefore no rear speakers.. if he installs lower speakers does he need a amp?? thinking about Hogtunes..
Old Feb 4, 2017 | 10:38 AM
Tailwind's Avatar
Tailwind
If u go aftermarket speaks u really should add an amp or u will not obtain any forward progress.
T
Old Feb 4, 2017 | 01:38 PM
Gannicus's Avatar
Gannicus
Yes Sir! He needs an amp. But he doesn't want the hog tunes speakers in his lowers! Much better options out there for the lowers. How much does he want to spend?
Old Feb 4, 2017 | 01:50 PM
Bushy's Avatar
Bushy
not surre just wo
ndering
Old Feb 4, 2017 | 06:52 PM
Bertk's Avatar
Bertk
not surre just wondering
Are you referring to the Hogtunes liquid cooled lower speaker kit?
Old Feb 4, 2017 | 07:04 PM
cpbedor's Avatar
cpbedor
Hey gannicus, have you gotten a chance to test the new hawg wired 6.5s?
Old Feb 5, 2017 | 08:16 AM
Gannicus's Avatar
Gannicus
Not yet. Waiting on CVO to send me a set. He's probably busy as hell like everybody else this time of year!! If he doesn't get to it in the next couple of weeks I'll pick up a set.
Old Feb 6, 2017 | 09:16 AM
Bushy's Avatar
Bushy
Yes I am Bert K.. looking at the entire system... I have a 15 and buddy has a 17,, I was thinking .. I;ll use the 4 with amp and hook him up with lowers since he removed his tour pack... Your thoughts??
Old Feb 6, 2017 | 12:00 PM
Bertk's Avatar
Bertk
There are several things to look at here.
The HT kits are mediocre at best. There are much better options out there.
As far as lowers go, speakers in that location fade very quickly at speed and that's with quality speakers and ~150watts of power. At about 45mph they fade to nothing buy background noise. With a combination of a weak amp and speakers as in the HT kit the only real sound you will get from the lowers is in the parking lot. In another thread Blue Tick used the HT lower kit and replace the HT speakers with Hertz EV 165'. There are not many options do to the limited space in the HT lower kit. You may want to reach out to him on how they perform going down the road before investing in lowers.
Fairing speakers are the main source sound on a bike and the best place to start. I would suggest adding the $340 the lower would cost into a quality amp and speakers for the fairing. This leaves you with a lot of options. On the Rushmore models a BT Line Leveler is a must have. The BT Speaker Brackets are a very good option and will allow the BT 7.1 speakers and most 6.5 speakers on the market. Otherwise you will limited to speakers that fit the stock speaker pods and in most cases reduced SQ.
Couple of questions:
What is your budget?
Are you comfortable installing these components or are you looking for a kit?
And what are your expectations of this upgrade?
Old Feb 6, 2017 | 12:53 PM
Bushy's Avatar
Bushy
I am looking at around 1000, have no issues doing install,, was looking for plug and play.. looking for good clean sound when riding... highway speeds mostly
and Lowers are not a real concern... fairing speaks and poss rear since most are the are usually sold as set
