Well, I readjusted the amp gain/sensitivity with the bike running, the was very little difference than when it wasn't running and plugged into the battery tender.
What I did find unusual, is the that I used 2 different test tones, both 1 Khz 0db.
I set the voltage to 24 using the first time, when I used the second tone it measured 1.5 ish volts higher.
Anyway, I went with the 1st one at 24 volts...
Time to put it all back together.
Looking at each test tone in MP3Gain they both have a different volume level.
The first one being 102.1 and the second 102.8
Choosing the lesser of the two is a safe move. This reinforces what several folks here have been saying that when done setting the target VAC, readjust the Gaines by ear for best sound and to confirm the signal is distortion free. A DMM is not a distortion detector.
You can see the volume in a application called MP3Gain.
Below is a screen shot of the two test tones in question.
Normally MP3Gain is used to automatically adjusts mp3s so that they all have the same volume. This reduces the need to keep adjusting the volume via the hand controls.
When you set the gains on the amp what was the volume set to on the HU?
Using the Boom HU it should have been 15. And once the gains are set, 15 should be your max volume.
Bert,
There were three more to go, not sure if that was 15 without counting.
If you adjust at 15 and never go higher, why not adjust at full volume, then you couldn't ever go higher.
I never knew you could adjust the levels on MP3 themselves!
Hours and hours of trial and error using traditional type tuning as well as using a distortion detector has proven that the Boom HU starts distorting a volume level 15. That's why it's advised to not set gains above that level.
Do both the 4.3 and 6.5 distort at the same level, 15?
Most all of the testing has been done with the 6.5 HU but I would think the 4.3 would be the same. The audio portion between the two HU's are the same. The only difference is the added capabilities of the 6.5.
