Bt355 install help
Old Mar 10, 2017 | 09:17 PM
Bike medic's Avatar
Bike medic
Default Bt355 install help
Gearing up to install my amp and speakers. My question is this. Do I tap into the factory wires at the head unit for the LL and then run new speaker wire from the amp to the speakers or utilize the factory wire? Am I better off doing it some other way?
Old Mar 10, 2017 | 09:26 PM
cpbedor's Avatar
cpbedor
What plug ends are on the end of your line levelers? if you aren't using a breakout harness, they should be the plugs that match up directly with the molex speaker output plugs from the HU.
You will grab the speaker outputs from the HU that feed into the LL and then RCA from the LL to amp then speaker wires to the speakers from thr amp.
Old Mar 10, 2017 | 10:18 PM
Tailwind's Avatar
Tailwind
Molex plugs just outside of each pod are the ones u t looking for for the front. Those r the HU output. After u plug those in the u RCA to the amp. Come out of the amp with speaker wire and u can run all the way to the speaker and splice new leads out Butt connect to the HD speaker wire and leads that were in the pods. U might need new leads regardless as it depends on the speak.
T
WVFLHX
Audio Systems
31
Mar 23, 2025 07:36 PM
Clutched
Audio Systems
Mar 16, 2019 10:42 AM
Neil
Jun 17, 2012 12:17 AM
wjl24
Jan 8, 2012 07:13 AM
AngryAmish1163
Feb 4, 2011 12:35 AM
