Normalizing MP3 loudness or gain
Old Mar 28, 2017 | 08:34 AM
hypecat's Avatar
hypecat
Default Normalizing MP3 loudness or gain
Does anyone have a suggestion for making an entire library of MP3s have the same or similar volume level?
I would prefer a Linux solution, but could use a windows based one as well.
Any advice is greatly appreciated!
Old Mar 28, 2017 | 09:20 AM
Roadie13's Avatar
Roadie13
MP3 Gain is a free download. Works nicely with MP3 tag. There are some old threads on here discussing it.
Old Mar 28, 2017 | 11:08 AM
Babyboy's Avatar
Babyboy
Mp3 gain is the program I use.
It is user friendly and let's you adjust the gain in the recording once it is down loaded on a PC.
The program will also let you know if the file is clipping
Old Mar 28, 2017 | 11:49 AM
hypecat's Avatar
hypecat
Can I give it an entire library at one time, or do I have to go file by file?
Is there a better way to rip MP3's? I used Windows Media player previously and don't think I had the same issue as i am now using Rhythmbox on Linux.
Old Mar 28, 2017 | 12:18 PM
Roadie13's Avatar
Roadie13
Originally Posted by hypecat
Can I give it an entire library at one time, or do I have to go file by file?.
You can do everything in a folder all at one time.
Old Mar 28, 2017 | 12:30 PM
Bertk's Avatar
Bertk
Agreed MP3Gain. Start out by setting Target Normal Volume to 93 dB.
Old Mar 28, 2017 | 01:23 PM
hypecat's Avatar
hypecat
Bertk,
93 Db, I like the way you think, seems most are settling on 89 Db!
So I can just put in for example c:/jj/music and let her rip? Do I have to specify a destination directory, if not, will it overwrite the MP3s where they are? Thoughts?
Old Mar 29, 2017 | 02:22 AM
Bertk's Avatar
Bertk
Bertk,
You can simply drag the files or folder into MP3Gain and run track analysis and track gain. The changes are saved within the file. There is a undo option.
http://mp3gain.sourceforge.net/faq.php
Old Mar 29, 2017 | 11:17 AM
hypecat's Avatar
hypecat
Bertk,
What if tracks show that they are clipping?
Do I adjust track gain or album gain?
Old Mar 29, 2017 | 11:35 AM
Bertk's Avatar
Bertk
Bertk,
There are several reasons a track will show clipping. Best thing to do is listen to the song and judge for yourself.
