4 awg coming off battery up to the pdb.
Are you using one fuse (and what size?) at the battery or several inline fuses off the pdb dependent on amp draw?
I have it set up a little differently:
4 ga off the battery to a 100A fuse 6" off the battery into fused distribution block with 50A fuses on each line out.
oh believe the hype, my fused distribution block is BURIED on the clutch side of the radio where the CB used to sit. I'd have to disassemble a good majority of the side of the bike to replace a fuse. but it's fused!
I have 4 gauge form the battery with an inline 100 amp fuse 6" from the battery to a fused distribution block in my fairing.
60 amp fuses with 8 gauge to each of my TM400's, I have a 4 position block for future expansion (was using a 50 amp for the Sony MEX-M100BT as it had it's own power supply).
