Wiring/Install Question
Old May 3, 2017 | 02:57 PM
bigh8840's Avatar
bigh8840
Default Wiring/Install Question
I'm just wanting to clarify a few things before ripping my fairing back apart. I'm switching my audio around...again. I'm coming from a bt4180 running hcx690 and mpk165p3 to a Diamond hxm800.4 pushing DD VO6.5/B3 and either hcx690 or DD's pro audio 6x9.
I've always been running a Cerwin Vega B54 bridged to a pair of sv200.1.
There's a good chance I'm changing my 200.1 to the DD W8 as well.
My main question is about wiring and capacitors. I have PAC bass blockers for the horns unless the capacitor that DD includes is a better fit (if so I lost one and need to buy one, where can I?)
I have both a SMD DD1 and CC1 that I've borrowed and didn't know what I need to set the crossovers too.
I'm confused on how to wire in the horns off the speakers.. I guess I'm overthinking it and all over the place. Any help is appreciated, as always thanks in advance.
Old May 4, 2017 | 07:01 AM
09baggerdude's Avatar
09baggerdude
Run the capacitors that came with the DD horns. Might call DD direct to get a replacement or whomever you bought them from.
You can twist and solder the wires from your speakers and horns. Just run them in parallel.
Harley_Newb419
Audio Systems
Apr 22, 2017 06:59 AM
Bigdave12768
Audio Systems
14
Jun 2, 2016 06:51 PM
rwb1
Audio Systems
May 27, 2014 09:06 PM
1sweetglide08
Audio Systems
Apr 8, 2013 06:24 AM
Qball
Sep 8, 2006 12:15 PM
