CB Woes
Old Jun 18, 2017 | 06:54 AM
Crew Dawg's Avatar
Crew Dawg
Stage I
Default CB Woes
CB Woes
I have a 2009 Ultra Classic. My problem is my CB radio. I got. CB turned on, Volume works with intercom off CB volume works, with the intercom on both volumes, work, Squelch opens up when the switch is pushed to full open. When I key the mike I get the channel indicator turning to black and white. Meaning transmission. happening? But no one can here me and our group is communicating between themselves, and I can not hear them. Again no one can hear me. The last time I worked in the area was when I had to replace my comm. connector on the fuel tank. Also, the shop did a 10,000-mile checkup, a stator change, and rear brakes replaced. All within a week of CB failure. Could I or they have crimped the antenna wire? How can you hook up an SJR meter to your antenna cable? I removed the antenna and the connector was not a common CB connector. Is there a common place to look for a crimped antenna wire? What else would you have me check? Lost in the smell of ozone.
wdeertz
Audio Systems
21
Apr 7, 2021 11:56 PM
JerseyJarhead0311E5
Apr 16, 2018 08:05 AM
ke5rbd
2014-2024 Touring Models
Aug 13, 2014 05:52 PM
Rusty-flhx
Feb 23, 2012 10:14 PM
05Fatty
Mar 16, 2008 04:38 PM
