Removing Factory Antenna Wire
Old Mar 16, 2008 | 07:01 AM
05Fatty's Avatar
05Fatty
Default Removing Factory Antenna Wire
How do you remove the factory antenna wire? Where is it routed through?
Old Mar 16, 2008 | 07:47 AM
WichitaGreg's Avatar
WichitaGreg
Default RE: Removing Factory Antenna Wire
I guess you are talking about the radio or CB antenna on an Ultra?
Remove and toss? or replace?
The antenna wires start on the back of the radio unit. You have to remove the front half of the fairing. Unscress the antenna cables and feed them back through the fairing. The are inside a wire boot, and I just cut mine off there, and where they came out under the tank. I laid my own wire and put a duplexer on it so I can use one antenna for both radio and CB.
The CB antenna was a single strand of about 28 gague copper wire inside a hollow casing. I replaced it with RG8. Used an antenna analyzer to tune a much better antenna for low SWR and much improved reception and transmission. AM radio suffers, but FM is just as good.
Two antennas are not the optimal set-up as the CB antenna will couple with the FM antenna and rob your signal during transmission.
Old Mar 16, 2008 | 09:54 AM
hogdoc's Avatar
hogdoc
Its routed THROUGH the main harness conduit. If your not using the antenna at the rear of the bike just bundle it under the left side cover just like the FLHT standards have them from the factory.
Old Mar 16, 2008 | 01:31 PM
racklefratz's Avatar
racklefratz
ORIGINAL: WichitaGreg
Antennas are cut to even fractions of the wavelength for the frequency band it will be used for. CB band is around 29Mhz. FM is 88-107 Mhz. Wavelengths and their fractional equivalents (1/2 wavelength, 1/4 wavelength, etc) are quite different. I doubt the two antennas interfere with each other, which, maybe not surprisingly, may be why the HD design engineers thought they might be able to pull it off.
Old Mar 16, 2008 | 04:38 PM
05Fatty's Avatar
05Fatty
Thanks guys.
JerseyJarhead0311E5
Apr 16, 2018 08:05 AM
Gonzy
Audio Systems
Nov 24, 2013 11:18 AM
bgdv1
Audio Systems
Sep 15, 2011 01:24 PM
rickshog1
Jun 2, 2009 12:49 PM
THABULL
Mar 18, 2008 09:04 AM
