More help needed guys. Lower speaker connections.
Old Jul 4, 2017 | 10:59 AM
danzio's Avatar
danzio
Default More help needed guys. Lower speaker connections.
So my Ultra obviously has rear speakers but I have a removable tourpak and seldom have the TP on anymore. My rear speaker wires are quick disconnects and store under the seat.
Question: How do I get the newly installed speakers in my lowers to connect to my amp using the stock radio with PAC Line Out converter. I understand you just connect the existing speaker wires to the LOC but how do I find the rear speaker wires under the fairing and if I do, am I supposed to cut them under the fairing? I really don't want to lose the rear speaker wires/connections in case of future upgrades.
Any help appreciated.
Old Jul 4, 2017 | 11:18 AM
cpbedor's Avatar
cpbedor
Youll be running new speaker wires to the speaker locations from your amp. When you run the rears, the will travel the same line as your power and ground cables past the battery and you will snake a wire on each side into the existing grommet. The stock speaker connections will just sit there To make them quick release you will install Deutsch Connectors. You have the option to use a 4 pin and group both wires into the same connector or two 2 pin connectors. This will allow your TP to remain quick release as well as keep your wires waterproof.
Amazon Amazon
-- 4 pin
Amazon Amazon
--- 2 pin
Old Jul 4, 2017 | 11:36 AM
danzio's Avatar
danzio
https://www.amazon.com/dp/B01G9V3U8C...l_huc_continue -- 4 pin
https://www.amazon.com/Deutsch-2-Pin...onnector+2+pin --- 2 pin
Thanks for your reply, but I may not have been clear. I already have the deutsch connectors for my TP. I don't use them but I don't want to lose them either. I already have my lowers installed with speaker wire running up to the amp. I need to know how to get these lower speakers connected to my HU.
Thanks,
Dan
Old Jul 4, 2017 | 11:51 AM
Gannicus's Avatar
Gannicus
Thanks,
Dan
All you have to do is connect your speakers wires to the amp. As long as you have RCA's running from the back of your HU to the amp. You're good.
Old Jul 4, 2017 | 12:08 PM
danzio's Avatar
danzio
Gann,
I'm running the stock HK head unit (sorry, I mentioned that in another post and then started this one). There are no RCA's.
2007 Ultra.
Cerwin Vega B54
Kappa 6211i's upper and lower fairings.
Old Jul 4, 2017 | 12:22 PM
Gannicus's Avatar
Gannicus
Gann,
2007 Ultra.
Cerwin Vega B54
No worries bro. Speaker wires still go to the amp. If your running the stock HU that means you're using the speakers wires from the fairing for INPUT. If you have a 4 channel amp all you need is two PAC SNI-15 line levelers for your INPUT to the amp. All your speaker wires will come off the speaker side of the amp.
Old Jul 4, 2017 | 12:38 PM
danzio's Avatar
danzio
Thanks Gann, I'm just not clear on obtaining the second set of speaker wires for the lowers. Or am I making this more complicated than it should be? I have the two PAC SNI 15 LOC's and understood that the front speaker wires will plug into one of those LOC's. My question is what to do with the other speaker wires coming in from the lowers. Speakers are in and wires are run. Am I making any sense?
Old Jul 4, 2017 | 01:08 PM
Tailwind's Avatar
Tailwind
Let's back the bus up a bit.
Sound comes from ur HU, then via high level Input (Hu wire) or low level Input (HU wire to LOC then RCA, then EITHER OF THE ABOVE AMP INPUT METHODS YOU CHOOSE plugs into the amp. From there ur speaker wire will go to front, lowers or rear. U can run some of that in parallel should u want to drop the TP on and have it work.
T
Old Jul 4, 2017 | 01:32 PM
danzio's Avatar
danzio
I'm sorry guys, I don't think I'm being clear.
Let me try and ask it like this........Do I tie the new speaker wires coming from the lowers into the same existing speaker wires from the original front fairing speakers. So in essence both PAC's as well as both pairs of speakers will all be tied together? This will leave the existing rear speaker wire intact to upgrade TP speakers in the future if desired. I guess the only thing is this will not allow for the use of the fader, uppers to lowers. Am I thinking correctly on this?
Old Jul 4, 2017 | 01:50 PM
Tailwind's Avatar
Tailwind
Ur losing me with this PAC stuff brotha!!!!
One PAC feeds channels 1/2 and the other feeds 3/4 of the amp.
Run the front speaker output wire off channels 1/2 and use 3/4 for the rear and lowers in parallel.
Rear and lower speaks must be 4 ohm.
T
