More help needed guys. Lower speaker connections.
Old Jul 4, 2017 | 02:59 PM
Gannicus's Avatar
Gannicus
OKay bro! To add to T's explanation. You have two high level INPUTS in the form of your STOCK speaker wires. Positive and negative on the clutch side and the Brake side. These are the wires your stock speakers were hooked to.
You have two PAC line levelers. One for the right side and one for the left side. RCA female connections on one end. Speaker wires on the other end. You need two sets of RCA's for your line levelers. You have a Cerwin Vega B4 amp. The two sets of RCA's will plug into the amp on one end. The other end will go to the PAC line levelers. On the other end of the PAC line levelers are speaker wires +/- R/L. Again, these wires will hook to the STOCK speaker wires that your stock speakers were hooked to. Once this is done the INPUT side of the amp is DONE.
Nothing else to do on the input side.
Now you want to move to the SPEAKER side of the amp. Once there you will hook your fairing speakers to the front R/L. And the lower fairing speakers to the back R/L.
Hope this helps!
Old Jul 4, 2017 | 03:28 PM
danzio's Avatar
danzio
Hope this helps!
Thank you Gann, I think I got it now. You guys in this forum are some of the most giving dudes on the planet. I just spent 40 minutes on the phone with Tailwind and I am still amazed at how much you guys all give of yourselves and your knowledge.
Thank you again bro, and have a great 4th!
UltraBrian
May 8, 2017 06:07 PM
RufusT
Aug 2, 2016 08:13 AM
TwoBlue02
Audio Systems
May 11, 2014 09:48 AM
ZenGlide
Audio Systems
13
Apr 17, 2014 06:31 AM
wjl24
Jan 8, 2012 07:13 AM
