Question/Problem
Old Jul 12, 2017 | 11:34 AM
InthewindMN's Avatar
InthewindMN
Originally Posted by BaggerAudioLab
bike on means higher input voltage, means the amp puts out more power and could be clipping. The hotter the amp gets the lower it will play, and the sound quality will also decrease. That amp gets pretty hot when pushed bridged.
That makes sense. I never noticed this before with coaxial speakers, do these components draw more with the x over?
Old Jul 16, 2017 | 05:35 PM
KitedudeRD's Avatar
KitedudeRD
Default Same thing here...
Originally Posted by InthewindMN
I have a problem with my system and am looking for advice from the pros. I have a 2014 flhxs with bt355 LL, CV B54 amp (bridged) to AW 6.5 with T2 tweeters and crossovers. I installed the speakers this spring, the rest the winter before.
Problem...speakers cut out randomly at high volumes above 2/3. Sometimes its both speakers, sometimes its one or the other. Does it driving or parked.
I've replaced the line leveler, rca cables and amp pigtails to try to rule out a short. First instinct is that the amp is clipping. If I turn the gains down it goes away but I have to turn them so low that the speakers dont seem to come to life. I've had several sets of coaxial speakers on this amp and never had it cut out like this.
Question....is it cutting out due to amp failure, wiring problem, or is this component setup putting a higher load on it causing symptoms not seen before?
Thanks for any help/advice.
I have the exact same problem, my audio starts clipping about 2/3 of the volume, mine is a FLHS 17 and I installed a RF PBR300x2 amp with IK 62.11 speakers , wasn't completely happy with the sound wanted something cleaner so I bought the BT LL and installed it, but didn't work properly since a channel wasn't working, even switched speakers to see if it was the amp or the speakers but no, my LL came with defects. And after that came the real problem. Now this thing is clipping don't know if the leveler messed my HU or the amp.
Lancemchn
Aug 4, 2018 11:32 PM
Softy 103
Audio Systems
31
Oct 19, 2014 09:08 AM
BigGelvis
Audio Systems
73
Oct 4, 2013 11:49 PM
Bagger_Vance
Audio Systems
Oct 3, 2013 05:01 PM
Toe Knee
Aug 2, 2012 06:28 AM
