BT pro installation issue '06 E Glide
Old Aug 3, 2017 | 11:45 AM
bladeguy's Avatar
bladeguy
Default BT pro installation issue '06 E Glide
My friend is installing BT 7.1 pros in his 06 Elwctra Glide. He mointed the adapters oriented as shown in the picture in the instructions. However, when he went to put the stabilizer bar back on it no longer lines up. Anyone else have this problem? What is the solution? I did not have this problem on my 12. Thanks,!
Old Aug 3, 2017 | 01:27 PM
BlackPearl#1's Avatar
BlackPearl#1
I had to extend that cut out or notch, whatever you call the part the screw goes thru in the arm. I also found that the other end of the bracket can use a little modification too. It'll work, break out the dremel.
Kris
Old Aug 3, 2017 | 02:55 PM
badazzpred's Avatar
badazzpred
I have an 05' EG you do not need to re-use them trust me!
bladeguy
Audio Systems
Aug 3, 2017 11:20 AM
Motown Glide
Oct 14, 2007 04:36 PM
dan boudreau
Oct 9, 2007 10:41 PM
scofield333
Jul 14, 2007 07:17 PM
FXST
Aug 3, 2005 11:36 PM
