Intercom wiring questions
Old Aug 25, 2017 | 12:20 PM
ScottinAZ's Avatar
ScottinAZ
Default Intercom wiring questions
Ok,
First a bit of backstory.
I am installing a 2012 Harmon Kardon head unit into a 2000 Ultra Classic. I will be re-doing the 23 pin connector with a new 35 pin connector. All I am doing is replacing one connector with the other (I have the pinouts, its not that difficult for the "stuff" I need).
The question I have regards the headset wiring only, as the 7 pin plug shows a difference in the wiring functions between the two setups. (appears + and - polarities are switched). Now that said that the wiring is different, when I look up headsets for the bike, they show the same from about 1998 onwards to the new bikes. This goes for the cable between the bike connector and the headset as well.
Is there truly a difference between the bikes up to 2005, and the 2006 and newer ones, or am I worrying about a non-issue?
Old Aug 26, 2017 | 07:50 AM
UltraNutZ's Avatar
UltraNutZ
Scott I'm pretty certain it's only a polarity switch.
tideguyinal
Electrical/Lighting/Alarm
Mar 16, 2019 09:43 PM
nightstalker2400
Audio Systems
Aug 16, 2018 08:48 PM
jimfreeman
Audio Systems
Sep 4, 2015 06:33 PM
texashillcountry
EVO
17
Nov 24, 2014 04:22 PM
wils5150
Audio Systems
Mar 20, 2013 05:50 PM
