why can't you?
Old Aug 31, 2017 | 08:45 AM
SOFTPETER's Avatar
SOFTPETER
You could use the Sony's MEX-M100BT. That has about 45-55watts of real power out of a radio.
Old Aug 31, 2017 | 10:42 AM
xtremer-pxl's Avatar
xtremer-pxl
Just seems crazy that wanting a little better sound quality and a little more volume cost.... minimum of $500
Old Aug 31, 2017 | 11:20 AM
Babyboy's Avatar
Babyboy
Do it right and spend the $$$ the first time your pocket will be better off. A lot of us here do A lot of testing of different combinations of speakers, amps and headunits to help out fellow members with proven combinations that work. In the long run saving others headaches and money.
You can take this with the grain of salt or how ever you want but researching and asking question is the best solution before you purchase anything.
Take the input given here figure out the products you are looking at post them and you may get a thumbs up or a correction on your choices.
Old Aug 31, 2017 | 06:13 PM
yooperhog's Avatar
yooperhog
[QUOTE=Babyboy;16588330]Do it right and spend the $$$ the first time your pocket will be better off. A lot of us here do A lot of testing of different combinations of speakers, amps and headunits to help out fellow members with proven combinations that work. In the long run saving others headaches and money.
pick out a head unit and carriage
add a handlebar interface
pick out some speakers
new price your probly at $350 already
check this forums classified for deals on great used stuff
if you stick $350 into it without an amp... you will be very disappointed
even the highly regarded and affordable kappa infinity speakers want at least 150 watts
they work great with budget amps such as cerwin vega and soundstream
Old Aug 31, 2017 | 09:25 PM
xtremer-pxl
Any opinions on the Alpine 445u amp?
Old Aug 31, 2017 | 09:47 PM
FLYINGBROKE's Avatar
FLYINGBROKE
I second the go to for sale section almost all items where yesterdays best thing most folks start out mild then go wild .very little play time on most of it.use search on your amp questions if no info that's a good reason to skip it .would be hard if not impossible for there to be good amp out there that has not been tried stick to tried and true.2cts
Old Sep 1, 2017 | 03:00 AM
yooperhog's Avatar
yooperhog
even bridged to 2 channel it is underpowered fo bike audio
Big trucker
Audio Systems
Jul 31, 2018 01:15 PM
Quickrunner1
Audio Systems
May 15, 2017 08:03 AM
pworks
Audio Systems
11
Oct 9, 2015 05:46 PM
big TYME
Aug 22, 2014 04:46 PM
