I'll be doing my install soon & this is one of the last items I need. Is everyone using the BT355 for the sole reason of the plug & play feature or is there something that makes it better than every other brand out there? Any reason not to use a PAC or Scosche? I've seen the Cycle Sounds Magic Box mentioned but it appears they are out of business.
One more question. On Biketronics website, there is a box to check for the 4.3in or 6.5in radio. Is there a difference in the converter or is that just a default in their ordering software?
I thought about that, I've always been taught to keep the grounds as short as possible.
It all goes back to the battery my man. So what's longer, a long cable direct to the battery, or a short ground cable and all the sheet metal your running through (back to the battery)?
I like to keep things tight and just ground to the frame/body. Obviously do the necessary prep and test of whatever you're connecting to if you go this route.
Up front on the bottom of the inner fairing there's a few bolts that work well.
