New Front Speaker Setup
Old Nov 9, 2017 | 07:31 PM
Stricnine's Avatar
Stricnine
Default New Front Speaker Setup
I just installed speakers and amp in my 16 RGS. It's a Biketronics BT355, B52 amp and Kappa 62.11 speakers. I've gathered all the info on here I could before I installed but wanted to verify my setup with the guys on here. I set this up by ear.
I have turned off AVC and set treble and bass flat (dead center). Set frequency to the 9 o'clock position but not positive this is 80 hz, sensitivity (gains) was turned completely down, and switched crossover adjustment to HP.
I started the bike and set volume to 3/4 and started to adjust the gains. Some songs sounded good at the 11 o'clock but others had some distortion so I settled at the 10 o'clock position.
I just wanted to verify that I didn't miss anything or should have done something different. Thanks for any of the guidance
Old Nov 9, 2017 | 09:13 PM
SBates08's Avatar
SBates08
Sounds like you've done everything correctly. Tuning by ear is crucial as you've experienced with your setup. May be a good idea to check your music source and make certain that all off your music is playing at the same levels.
Old Nov 9, 2017 | 09:31 PM
Stricnine's Avatar
Stricnine
Thank you SBates08. I'm currently playing mostly off USB. Most of the songs were ok when I had the gains turned up but a few had some distortion so I figured turning gains down some to play it on the safe side would be best.
Old Nov 10, 2017 | 09:47 PM
decencyxdefied's Avatar
decencyxdefied
There's a program to convert all ur songs to the same volume or dB watever it is lol..im sure someone will name it.. I've used it before with mixed results.. The songs that sounded low now song normal.. Others are super loud and all were done at the same rate.. Maybe I didn't do it right or something but maybe it'l help u dial in your system
Old Nov 10, 2017 | 09:54 PM
sponger's Avatar
sponger
Mp3gain.com
Old Nov 11, 2017 | 09:21 AM
MMXIWG's Avatar
MMXIWG
There's some caveats to using MP3GAIN alone. First is the default settings will not make an adjustment if it causes clipping. The gain setting is only changed up to the clipping point. This can cause some overly loud or soft files to not be changed as much as is needed. Second is that the clipping detection is overly sensitive IMO. I used MP3GAIN to analyze the volume levels but actually used Audacity to change the amplitude of the source files. Audacity also detects clipping but is not as strict as MP3GAIN. What I did was use the Limiter with makeup gain effect in Audacity to set all of my .mp3s at 95db. While using the limiter changes the source audio I haven't noticed any reduction in the sound quality that I can actually hear on the sled.
Something to remember - Don't decompress .mp3s. You lose some fidelity every time you compress a file into an .mp3. What I did was rip my CDs to uncompressed .wav files and used those as the source. If I had to make changes after I exported the file to .mp3 I started over with the original unmodified .wav file.
Overkill I'm sure and time consuming but I am very happy with the results.
Old Nov 11, 2017 | 03:16 PM
Stricnine's Avatar
Stricnine
Thanks guys. I just downloaded these.
TexasD
Audio Systems
May 7, 2018 11:48 PM
bigreds1963ss
Audio Systems
Oct 18, 2015 03:33 PM
Jason58104
Audio Systems
Aug 2, 2014 10:38 AM
Nickblink
Audio Systems
Jul 28, 2014 08:19 AM
parkashard
Audio Systems
17
Jul 21, 2013 10:57 AM
