Strange speaker noise issue
Old Nov 24, 2017 | 03:00 PM
TroubledWine's Avatar
TroubledWine
Default Strange speaker noise issue
2011 Street Glide. Setup is 8 months old. Sony MEX-M70BT, Cerwin Vega B52 amp, and Infinity Kappa 62.11 speakers. Stinger RCAs and ground wire ran to the battery. All wiring is soldered and heat-shrunk. Also have Alloy Art Strong Arm II inner fairing brackets.
Making a strange rattling noise/buzz and sometimes high-pitch whine ONLY on right side speaker. I swapped speaker sides to see if it was a speaker issue and it still only does it on the right side.
Not included in the video is an every-so-often high pitch interference noise. And ALL noise in this video is coming from the speaker itself. It's not my hand hitting the fairing or the inner/outer fairing being loose and hitting themselves.
Old Nov 25, 2017 | 07:15 AM
ew25950's Avatar
ew25950
I'm no expert by any means so hopefully this bump will get the better eyes on your post.
If you swapped the speaker and it stayed on the right side, I'd replace the speaker wire from the amp to the right side next. Others here mention not to solder speaker wires as they eventually rattle apart, try crimp and shrink wrap this time.
Old Nov 26, 2017 | 11:38 AM
BlackPearl#1's Avatar
BlackPearl#1
Try swapping sides with your RCAs. Had close to the same issue and it was a bad RCA. Not a stinger, but same type of noises.
Kris
Loujr28
Jul 22, 2019 10:28 PM
teedoff65
Audio Systems
Jul 14, 2019 05:52 PM
aaron5140
Audio Systems
Sep 17, 2018 01:49 PM
HDKozmo
Audio Systems
Jun 17, 2016 09:13 AM
bowhuntenbob
Audio Systems
Apr 7, 2015 04:44 AM
