Amp Recommandations
Old Dec 31, 2017 | 03:39 AM
Fireball Jack's Avatar
Fireball Jack
I have the 1000d in the fairing. need to shim it up about an inch. I used shipping foam from one of the speaker. I just cut it in strips and worked great. Not the cleanest amp but plenty load. Most lose their FM with it but I stream my phone or use my Ipod.
Old Jan 24, 2018 | 04:33 AM
65049's Avatar
65049
Originally Posted by USAproud
You can use that amp for 2 or 4 ohm speakers. I would think the soundstream pn4.1000d would be a better choice for few bucks more. It will have more than enough power to push those speakers, and fit in the fairing. I don't think the pn4.520d will be enough. Wait till others chime in to see what they say as I am very new to this game but do alot of reading.
I pulled the trigger on the pn4.1000d, where should I set the amp settings ?
Old Jan 24, 2018 | 04:53 AM
USAproud's Avatar
USAproud
Use the chart from the sticky about setting amp gains. I have the Polk mm652 and they sound real good around 150watts. Not sure about the 572. When you set them using chart this will be the ball park area. Use your ear and make final adjustment. Remember a little goes a long ways on those dials.
Old Jan 24, 2018 | 02:53 PM
65049's Avatar
65049
What about the Cross Over Selection Switch "LPF" or "FLAT" or "HPF" ? The sticky just talks about the gains
Old Jan 24, 2018 | 03:29 PM
65049's Avatar
65049
I'm probably going to have to mount the amp in the bag, with the amp all the way against the tach and speedo the fairing touches the amp not by much but it touches and not knowing how warm the amp will get
Old Jan 24, 2018 | 03:38 PM
USAproud's Avatar
USAproud
I would say flat and use your headunit to time crossovers but someone with better knowledge should chime in with real world experience
Old Jan 24, 2018 | 03:59 PM
SBates08's Avatar
SBates08
That amp will fit. It's a much easier install with an amp bracket from Badd Azz Bikes.
Either trim the backs of the gauges to allow it to slide in further, or angle the amp as much as you can and use heavy duty zip ties to hold it in place.
Set the amp on FLAT and use the crossovers on your HU. Set between 80-90.
Old Jan 24, 2018 | 04:00 PM
USAproud's Avatar
USAproud
Thanks Bates for confirming
Old Jan 24, 2018 | 05:24 PM
65049's Avatar
65049
Saw a post in HD Forum about someone put this amp in a 2014 Ultra , looks like there was more room in that year batwing than my 2008
Old Feb 4, 2018 | 03:56 PM
Budda109's Avatar
Budda109
Originally Posted by haze324
Set your gains just shy of 12 o'clock. HPF for both speakers should be set to about 60-70hz and let her rip.
Worked for me!!
https://www.hdforums.com/forum/audio...-question.html
