Amp Recommandations
Old Feb 20, 2018 | 08:54 AM
65049's Avatar
65049
Originally Posted by SBates08
That amp will fit. It's a much easier install with an amp bracket from Badd Azz Bikes.
Either trim the backs of the gauges to allow it to slide in further, or angle the amp as much as you can and use heavy duty zip ties to hold it in place.
Set the amp on FLAT and use the crossovers on your HU. Set between 80-90.
Where should I set the cross over setting on the amp ?
Old Feb 20, 2018 | 09:12 AM
SBates08's Avatar
SBates08
If your using the crossovers in the HU and have the amp set to flat, the crossovers on the amp are deactivated. Crossovers on the amp only work in HPF and LPF mode.
Old Jun 18, 2018 | 06:22 PM
65049's Avatar
65049
SBates08 I have a question, my Kenwood HU took a **** I have installed a stock Harley HU still using the amp, do I use the same settings on the amp that I used with the Kenwood ?
Old Jun 18, 2018 | 06:59 PM
SBates08's Avatar
SBates08
Since you no longer have crossovers in the HU, you'll need to use the HPF on the amp. Set the dial around 10:00 and that should put you in the 80-90 range. Set treble and bass on HU to flat (in the middle) and with volume at 3/4 adjust gains on the amp until you hear distortion and back off a touch. If you feel like the speakers are distorting a bit prematurely, rotate the HPF freq dial clockwise just a tad. Make sure bike is running when setting the gains. Once finished you can adjust treble and bass accordingly.
Old Jun 23, 2018 | 07:52 AM
65049's Avatar
65049
Why is it that you loss FM when you use the SoundStream PN4.1000D amp?
Old Jun 24, 2018 | 11:32 AM
65049's Avatar
65049
Originally Posted by Fireball Jack
I have the 1000d in the fairing. need to shim it up about an inch. I used shipping foam from one of the speaker. I just cut it in strips and worked great. Not the cleanest amp but plenty load. Most lose their FM with it but I stream my phone or use my Ipod.
What is cause of losing FM ?
Old Jun 24, 2018 | 12:23 PM
Tailwind's Avatar
Tailwind
EMI on Class D amps. Some far worse than others.
http://rftech.custhelp.com/app/answe...ation-advisory
T
Old Jun 24, 2018 | 12:29 PM
SBates08's Avatar
SBates08
T
Beat me to it T. I was just about to link the same article. It's a very in depth read but it explains it well. Most of your higher end Class D amps do not suffer from this.
Besides...who listens to FM on a bike anymore?
Old Jun 24, 2018 | 02:00 PM
65049's Avatar
65049
Thanks guys, I normally use my ipod. I have another question. I just put a factory HD radio in, when I plug my ipod in with aux line it doesn't get loud, when I had my aftermarket radio and plugged the ipod in with usb it got loud . Is there any settings on the HD radio. The bike is 2008
Old Jun 24, 2018 | 03:55 PM
Tailwind's Avatar
Tailwind
I primarily an iPod and have never had a prob with inconsistent volume.
Is the volume on ur iPod set at 3/4?
T
