quick amp question (help me choose)
Old Feb 2, 2018 | 08:25 AM
DURAMAX_LBZ's Avatar
DURAMAX_LBZ
Default quick amp question (help me choose)
i am gonna do a little upgrading and going to put the infinity kappas in the fairing as to what most of you say to use on the forums as for the amp i saw that some say the sound stream amps are good and cheap so i guess i am looking for a amp that will work with the 2 kappas but will also have the ability to maybe add 2 more speakers in the bags if i ever decide to do it down the road , so should i get the
Soundstream pn2.350d
soundstream pn4.520d
soundstream pn4.1000d
thanks in advance
Old Feb 2, 2018 | 08:33 AM
Gannicus's Avatar
Gannicus
thanks in advance
What Bike?
Old Feb 2, 2018 | 12:58 PM
DURAMAX_LBZ
13 street glide
Old Feb 2, 2018 | 02:26 PM
Gannicus's Avatar
Gannicus
13 street glide
SS PN4.1000D. Hands down.
Old Feb 2, 2018 | 02:49 PM
DURAMAX_LBZ
Thanks is there a Amp bracket I will need or am i going to have to fab one
Old Feb 2, 2018 | 03:30 PM
SBates08's Avatar
SBates08
If your staying with the stock head unit I don't believe there's an amp mount that'll work for that amp. It will however fit between the fairing braces. Just barely. Awesome budget amp.
Old Feb 3, 2018 | 08:07 AM
DURAMAX_LBZ
thanks guys i ordered the amp speaker and rings now i need to get the wiring i am gonna get 8 gauge for amp and 16 for speakers the only thin i am unsure of is does the factory radio have rca or will i need a adapter?
Old Feb 3, 2018 | 08:12 AM
SBates08's Avatar
SBates08
No RCA connections on the radio. You'll need a PAC-SNI 35 to convert to RCA. One for the front and one for the rear.
Old Feb 5, 2018 | 09:38 PM
DURAMAX_LBZ
Not sure if I should make a new thread or not but have a couple more questions on the install. I ran all the wires install the speakers and just have a few questions on line out converter I never installed one before does the wires coming out of it go to the OEM speaker wires then I connect RCA's from that to the amp correct? Also I just connect each speaker to the left and right front Channel?
Old Feb 5, 2018 | 09:52 PM
SBates08's Avatar
SBates08
You're thinking is correct.
