Polk MM652 grills
Old Feb 6, 2018 | 12:38 AM
DAVENRINO's Avatar
DAVENRINO
Default Polk MM652 grills
Has anyone found a good grill for the 652's? I am going to use them in the TP pods and the grills don't look that protective for that location.
Thanks,
Dave
Old Feb 6, 2018 | 01:49 AM
travelingypsye's Avatar
travelingypsye
I don't have a tp but wondered that myself. If it were my, I would try to get some that screw on instead of snap on. What grills are you running up front? I just realized you are in Hawaii. No wonder you are here so late. You're 6 hrs behind me. I lived on Kopiolani Blvd in Honolulu when I worked at Tripler Med Center. I was there 9 months in their ICU. Love that place.
Any way, I would try to match the front grill as much as possible.
Old Feb 6, 2018 | 08:49 AM
macabra11's Avatar
macabra11
I am curious to know what is recommended as well. I will be putting lowers on my FLTRXS soon, and am going to put my MM652s in them. I agree the grills do not offer enough protection (and they are fugly). My plan at this point is to use the grills I have from my Arc Moto 602s, but I have no idea if that will work or not???
Old Feb 6, 2018 | 11:28 AM
Gambat's Avatar
Gambat
I used the HD Boom grills. You have to push the center out a bit to clear the tweeter. I did this with a large and small diameter PVC pipe pieces with the grill laying on a folded towel to allow them to move outwards and protect the finish. Did this a few times until I was happy. I saw it in the tread https://www.hdforums.com/forum/audio...t-glide-2.html. My only problem was the speaker and grill holes didn't line up perfectly.
Old Feb 6, 2018 | 01:12 PM
DAVENRINO's Avatar
DAVENRINO
Was this in the fairing or the TP pods? Assuming the Hogtunes grills are the same as the Booms, I wasn't sure if they would mount outside the Polks when flush mounted to the rear pods.
Thanks a lot for the info.
Dave
Old Feb 6, 2018 | 01:36 PM
twspalm's Avatar
twspalm
Here's what I used in my TP. Perfect fit but I think I had to go to Ace Hardware and get some longer screws.
https://www.ebay.com/itm/221938557522
Old Feb 6, 2018 | 02:15 PM
Gambat's Avatar
Gambat
Dave
On the TP pods. There cost more than the Hogtunes but I had a gift card so went for them.
Old Feb 6, 2018 | 02:16 PM
DAVENRINO's Avatar
DAVENRINO
Cool, I will get those. As macabra11 said, the stock ones are fugly and I already have Hogtunes grills for the front.
Thanks
SgtMic
Audio Systems
23
Mar 18, 2017 09:17 PM
GoGetter5832
Sep 22, 2013 10:36 PM
