Need Some Audio Help
Old Mar 24, 2018 | 02:35 PM
Tailwind's Avatar
Tailwind
Originally Posted by Cmac69
Should I do the ultra harness kit to make it easier?
Nope. We can just run speaker wire at 1/10th the cost.
You will need the Biketronics BT355s for ur specific sled. That allows u to plug into your sled and not cut a single OEM wire. The rest is basic audio wiring with a couple quick disconnects at the bags.
T
Old Mar 24, 2018 | 02:42 PM
Cmac69's Avatar
Cmac69
two of the BT355 correct
Old Mar 24, 2018 | 02:43 PM
Cmac69's Avatar
Cmac69
Do I want two of the front ones
Old Mar 24, 2018 | 03:33 PM
Cmac69's Avatar
Cmac69
anyone if I get a single 4 channel amp instead of two amps how would I wire that up a single bt355?
or two bt355 ?
Old Mar 24, 2018 | 04:32 PM
Kenbow's Avatar
Kenbow
If you want fade control "front to back" you will have to have the radio flashed and get two BT line leveler'. If it's not important to you then you will get a RCA Y cable that turns one output into two. Order the BT LL with front speaker connections.
Old Mar 24, 2018 | 04:41 PM
MMXIWG's Avatar
MMXIWG
If you aren't going to use the fade control and only one BT LL then you don't really need a radio flash because you won't be using the rear speaker outputs of the radio.
Old Mar 24, 2018 | 04:47 PM
Cmac69's Avatar
Cmac69
Right so one bt355 now how do I wire it up is it better to get a 4 channel amp?
And do I get rca splitters cause you need 2 sets im thinking?
Old Mar 24, 2018 | 05:17 PM
Kenbow's Avatar
Kenbow
I used this cable
Amazon Amazon
Old Mar 24, 2018 | 05:50 PM
Cmac69's Avatar
Cmac69
So you think I should do a single 4 channel amp or good with the two rockford ones
Old Mar 24, 2018 | 06:11 PM
Gannicus's Avatar
Gannicus
Originally Posted by travelingypsye
First the pbr amps are prone to overheat and I would not put them in the bags for that reason. They are also not a very good amp as they just don't do speakers justice. Loud but kinda sounds like a drive thru speaker at McDonalds. You can accomplish all 4 speakers off 1- 4 channel amp even if you only have 2 active outs on your head unit. The only thing you wont have is fade control. Don't throw good money away for not so good setup. As far as speakers go, the same principle applies. If you have polks mm series speakers then you are good to go, if they are the db speakers then not so good.
Reference the Gypsye post. You would be better off selling the Rockford amps and go to a 4 channel amp.
