Can some please tell me how to wire it up ok I will get a 4 channel amp but I have a stock radio so i have no outputs I can get a bt 355 and do a splitter do I need 4 speaker wires going in? Im lost lol HELP
Cmac what part of Chicago are you in??
I am.in the southwest suburbs so if our schedules are not conflicting maybe I could swing by and give you a hand if you would like.
I would set the parking brake for a bit brother. Ur still not sure what speakers u have but are wanting advise on an amp and wiring an amp u don't have yet.
Back up a bit and define the sandbox regarding current equipment ur committed to, budget, fade, pod eliminators, amp tray, genres u play, etc.....
@Tailwind read the post I know the brand its not about not knowing if you read my friend hooked me up with a basically brand new system 2 amps 2polk 6.5 and 2 rockford 6x9 someone said these amps not good they overheat so I wanted suggestions and some said 4 channel be easier than 2 2 channel amps so you need to slow your roll I appreciate everyones help I need it trying to make this work the best way possible doesn't really matter what model if I pop them bitches Ill buy new ones those are easy to change the amps and all that don't wanna do those 3 or 4 times
