Amp Challenge.
Old Apr 7, 2018 | 11:49 PM
Philokc's Avatar
Philokc
Originally Posted by travelingypsye
not yet.....
My ears say number 2 sounds better.
Old Apr 8, 2018 | 07:28 AM
MikeTD3's Avatar
MikeTD3
Likewise
Old Apr 8, 2018 | 08:50 AM
InthewindMN's Avatar
InthewindMN
Originally Posted by USAproud
What amps were tested?
Old Apr 8, 2018 | 10:45 AM
JRose609's Avatar
JRose609
first video seemed better.
Old Apr 8, 2018 | 11:00 AM
haze324's Avatar
haze324
How did you set both amps?
Old Apr 8, 2018 | 11:08 AM
yooperhog's Avatar
yooperhog
im gonna say 2
Old Apr 8, 2018 | 12:33 PM
Budda109's Avatar
Budda109
2 loader, 1 cleaner. Can you list your setup?
Old Apr 8, 2018 | 03:00 PM
travelingypsye's Avatar
travelingypsye
Both amps set up with hp filters front at 80 rear at 60. Gains just a tad off max at 3/4 volume.
So far the tally is:
#1 amp= 6 votes
#2 amp = 3 votes
Very interesting on these votes.
Old Apr 8, 2018 | 03:19 PM
haze324's Avatar
haze324
#1 amp= 6 votes
#2 amp = 3 votes
ive ran the same voltage out of two amps and had to either raise or lower the HPF because of the sound each different amp produces. When you say gains a tad off max, was that max on the dial, VAC setting, or DDM? So you might be able to get better sound out of one or another amp.
Old Apr 8, 2018 | 03:28 PM
travelingypsye
You are right on the different settings. I tuned both these the old fashion way by ear. I have used a digital volt meter in the past but found that doing it by ear was better as you know using a volt meter on different amp/speaker set ups solely can let some left on the table.
