Lower fairing speaker question
Old Apr 15, 2018 | 05:41 PM
Markj391's Avatar
Markj391
Stage II
Default Lower fairing speaker question
Recently installed lower fairing speakers adapters in my ride with 6.5" Kicker speakers. The speaker adapters are a pretty closed in unit with the exception of the fairing mounting bolts. Do I need to ventilate these adapters to let the speakers breathe? Should I use sound deadening in these as well?
Thanks!
Old Apr 16, 2018 | 08:31 AM
bubisa050's Avatar
bubisa050
2nd Gear
I think you don't have to, they will work fine as is. But if you care about improving the quality of sound than yes. But it will be a slight change.
Old Apr 16, 2018 | 07:10 PM
duglaura&flhti's Avatar
duglaura&flhti
First post needs a welcome, howdy, how you doing? My lowers Hertz sounds great without anything in the lowers...You should be fine....What Class D amp you running?
Old Apr 17, 2018 | 06:09 PM
Markj391's Avatar
Markj391
Stage II
I'm running a Rockford Fosgate 4 channel 400 watt amp.
Ecolesh1166
Audio Systems
Feb 7, 2017 06:26 PM
GoatHD
Audio Systems
Apr 14, 2014 06:41 AM
derk8088
Sep 26, 2012 01:59 PM
PWFD
Aug 3, 2012 11:37 AM
blown alcohol
Sep 23, 2009 03:09 PM
