Install Help...Pics/Diagrams
Old May 24, 2018 | 09:55 AM
Blue Tick's Avatar
Blue Tick
Originally Posted by InthewindMN
that looks right for the front connectors
Thanks....sorry for all the questions. On the Y splitters 1 or 2? How did you connect them with only having the 2 rca plugs on the LL? I'm thinking now I can set it up as you have pictured, run speaker wire to the back, flip the amp to 4 channel and set the gains. I know it gives up fade, but thats not an issue. Hopefully my thinking here isn't flawed. Maybe someone with an ultra setup will chime in soon.
I do appreciate your help.
Old May 24, 2018 | 10:19 AM
InthewindMN's Avatar
InthewindMN
Y splitter have 2 plugs on one end and one plug on the other. The single plug goes in the LL, the other two go in the amp. If you are using all 4 channels of the amp then hook up the y to both front and rear of the same color rca jack, other y to the other color jacks. The manual for the amp may even have a diagram on this.
Old May 24, 2018 | 10:59 AM
Blue Tick's Avatar
Blue Tick
Thanks....then I will need 2 Y splitters, guess I could have probably been a little more clear on that. I was under the impression that 1 y splitter would have to plug into both spots on the LL, but your explanation makes sense to me. So 2 Y splitters each plugged into the 1 LL, rca's then plugged into matching color slots on the amp.
What amp tray is everyone using, factory, biketronics or jm?
What settings for the amp? HP, LP or all pass? Set freq to 80? Then volume to 3/4 and adjust the gains?
Old May 24, 2018 | 11:01 AM
InthewindMN
Hp 90 is a good place to start.
Old May 24, 2018 | 08:48 PM
Blue Tick's Avatar
Blue Tick
Who can tell me whether the hcx's or wdx moto's will mount up to the front fairing pods or do I need to make mods for them to fit? I ordered some hawg wired mesh grills today. Suggestions on any other speakers to look at for the front? For the rear pak pods I know the evf's will drop right into the pods any suggestions there for others to look at? If their not a direct drop in, what is everyone doing for spacers?
Thanks.
Old May 24, 2018 | 08:55 PM
InthewindMN
Motos will fit by trimming a little on the inside ribs. You may need to take the grills off the tweeters.
Hcx will fit but you may need to shim the pods out a little to keep them away from the inner fairing.
Old May 24, 2018 | 09:22 PM
Dsm Limited's Avatar
Dsm Limited
Hcx's fit in my pods with no mods to the pod. As been said the DB motos will need to have inner ribs trimmed.
As for rear pods, the mm652's and Cx62's fit in tp. I use a pioneer triaxial that's also a drop in choice
Old May 25, 2018 | 07:47 AM
Tailwind's Avatar
Tailwind
Unless u have the ability to tune the DB Motos I would consider the Euphoria EPC6 instead. Same price point.
T
Old May 25, 2018 | 08:53 AM
Blue Tick's Avatar
Blue Tick
I thought there was some issues with the mm's and cx's needing adapters? Or is it just a matter of spinning them for them to drop in?
Old May 25, 2018 | 08:55 AM
Blue Tick's Avatar
Blue Tick
T
I thought the DB's were pretty efficient? Is the Diamond 4v2 not enough to run them right? Thanks.
Edit: T are you talking about these for the pak pods? Recommendations for the fairing???
