Stumped on amp not powering up
A little back story. A couple of weeks ago I seemed to have a bad channel. In the troubleshooting process I swapped from a Power Acoustik RZ 4-3000D which I'd been running for a good while to a Soundstream PN 4-1000D. The PA is a clone of the SS. My problem turned out to be the Sony head unit, but since the SS was already in place I just left it in. Mind you that the PA was functional, but I put it up on the shelf. New Sony went into place and all was well until yesterday. Riding down the road listening to a radio stream from my phone when I hear a loud pop and everything goes dead. The amp is wired directly to the battery. I pulled the seat and checked the fuse, it's good. I pulled the fairing, turned on the ignition, no power light on at the amp. Put a voltmeter on it, 12.75 applied to the amp. I figure the amp went bad, although it only had maybe 6-10 hours on it. I got the PA off the shelf and connected the power leads and remote turn on back up but it won't power up. This is a known good amp, working when removed. So now even though I've got voltage to the amp, neither one will turn on. What am I overlooking?
