CB Transmit Problem
Old May 23, 2018 | 03:07 PM
IUOE ROB's Avatar
IUOE ROB
Default CB Transmit Problem
Greetings...I recently changed out the battery on my '14 Limited, 19K miles. A little background, I replaced the handlebar switch packs about 2 years ago with lighted ones. I also have had the software update done that changed the CB PTT button and the Cruise Control button, the PPT button is now on the left side and the CC button is now on the right side. While changing the battery I had a problem with the alarm sounding so I pulled the main fuse. Put everything back together and everything seemed to work fine. While on a recent ride I noticed that I can not transmit with the CB. I can hear others fine but can't transmit. I also tried the phone and that worked fine so I know it's not the headset. I just went out and tried the old (non-lighted) switch pack thinking maybe the PTT Button on the lighted one wasn't working but that one didn't work either. I also tried pulling the main fuse but again no good. Any thoughts? Maybe the CB module itself? I'd like to try all the obvious things before I bring it into the dealer...thank you!
Old May 26, 2018 | 10:15 AM
cficole's Avatar
cficole
Did you try using a meter on the wires to the PTT switch? Check for switch operation and grounding, with wires disconnected from anything.
Old May 26, 2018 | 10:24 AM
IUOE ROB's Avatar
IUOE ROB
Thank you for your reply...I posted this same problem in the Rushmore section and after getting a few suggestions I narrowed it down to a software problem. I tried a system reset, that didn't work, replaced the questionable handlebar switchpack with the OEM one, that didn't work but after upgrading the Boom software to a later version (against my better judgement, LOL) everything now seems to be working. Both PTT buttons (front and rear) are now functional. Thanks again for your help...
Old May 27, 2018 | 10:28 AM
cficole's Avatar
cficole
Glad you got it fixed.
semelsje
Dec 11, 2022 11:07 AM
IUOE ROB
2014-2024 Touring Models
22
Jun 1, 2018 12:24 PM
IUOE ROB
May 9, 2018 03:03 PM
vhmike73
Audio Systems
Jun 6, 2015 02:55 PM
cycleman50
Jun 22, 2009 09:18 AM
