mike won't send
Old Jun 20, 2009 | 07:54 AM
cycleman50's Avatar
cycleman50
Unhappy mike won't send
I have an '02 ultra. Recently I have found that my mike will NOT work. I can hear them speaking on channel 19 etc. of the cb, but I can not broadcast. The intercom also does not pick up my talking. I have two head sets with mikes and neither one works so I am figuring it must be something in the connections. I think I checked all the fuses and they seem OK.
Is there an internal fuse or does anyone have other ideas why it doesn't work? Oh, when I push down to talk channel 19 shows up on display. The intercom does not show when I yell into mike. Thanks for any suggestions on how to fix problem.
Old Jun 20, 2009 | 08:13 AM
nocarb's Avatar
nocarb
Is your speaker switch set properly. If 3 position switch is in the middle, this is what you will have. Make sure switch is in the down position. The lighted part will be all the way down.
Old Jun 21, 2009 | 01:13 PM
cycleman50's Avatar
cycleman50
Yup, switch is correct. I am wondering if the problem would be in the harness or the radio.
HD dealer said hard to tell. Either have to send radio in to be reconditioned or just start replacing parts till problem is solved. I looked at connections to radio and all look OK, no loose wires etc.
Old Jun 21, 2009 | 02:23 PM
JMJOHN's Avatar
JMJOHN
Sponsor
I would try a friends known GOOD headset, J&M or Harley brand to make sure it is your system before I tore it all apart ,,,, plugged in by itself, and then talk to yourself over the intercom, with the intercom volume at max ,,,,,
could just be your headset connection cords ,,,, and one bad one could short out both mikes ,,,,
JMJOHN ,,, john@jmcorp.com ,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Jun 22, 2009 | 09:18 AM
cycleman50's Avatar
cycleman50
Thanks for the suggestion. I'll try that next before spending more money or tearing bike apart.
IUOE ROB
2014-2024 Touring Models
22
Jun 1, 2018 12:24 PM
papabear64
Aug 23, 2017 06:43 AM
StreetGlide515
Audio Systems
Sep 29, 2015 06:36 AM
mtstringer
May 12, 2014 11:57 AM
Bigredone
Sep 29, 2007 07:52 PM
