HK Radio Going Crazy
Old Sep 29, 2007 | 06:46 PM
Bigredone's Avatar
Bigredone
Default HK Radio Going Crazy
It just started this crap today. While riding, it goes to Bass, Treble, and Fader settings for no reason. If I try to manually go to the settings, no response. Tried the update but no remedy. Suggestions?
Old Sep 29, 2007 | 06:56 PM
sleepman54's Avatar
sleepman54
Default RE: HK Radio Going Crazy
Probably means it needs to go into to the dealership so they can send it off for their wonderful refurb. Mine's going in for it's third time with the same problem, radio cuts in and out, doesn't matter if it's FM, CD, or Aux it cuts in and out. First two times they said I had a bare wire, can't figure out why it keeps coming up bare. Going to do this until the warranty is up, then I'll put in an aftermarket radio.
Old Sep 29, 2007 | 07:04 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Prolly a faulty switch, or an abraded/pinched wire shorting out at or near the switch housing.....
Loosen up the switch housings and see if there are changes in the affected events....
Don't forget the switches at the rear speakers as well....
You'll narrow down the affected string.... The stereo shares only 3 or 4 wires to make those switches work... But they are all on the same circuit... I.D. the faulty trunk, and you found your problem....
Old Sep 29, 2007 | 07:06 PM
drdiesel1's Avatar
drdiesel1
Water in the switch housing.. Used some compressed air. Open it and dry it out.[8D]
Old Sep 29, 2007 | 07:14 PM
Badbagger's Avatar
Badbagger
Get the dealer to replace it. Hopefully under warranty. Been there and done that and I think I am bout to do it all over again. I fire up the bike and twice now there has been a very loud buzzing sound, almost like feedback etc. I am going to take it back in and let them replace it yet again.
Old Sep 29, 2007 | 07:25 PM
hdjoe88's Avatar
hdjoe88
The HK radio is a POS. Many people on here have had problems, including me. Mine went within the first 6 months. Luckily mine was replaced at the dealership with a new one. Been OK since but many have had additional problems.[:@]
Old Sep 29, 2007 | 07:52 PM
choochoo's Avatar
choochoo
ines been changed out once and probably will be again.
SG-Jay
Audio Systems
Aug 14, 2017 08:20 PM
mtstringer
May 12, 2014 11:57 AM
greglcarlson
Feb 11, 2011 01:34 PM
shorty07ultra
May 24, 2009 10:38 PM
yoopermjm
May 31, 2007 10:18 PM
