Squealing from speakers
Old Jun 25, 2018 | 02:37 PM
2deuceguy's Avatar
2deuceguy
Default Squealing from speakers
Hey guys I’m looking for help with an issue I’m having. Bike is a 2012 road glide. It has an aquatics av AQ-MP-5BT-H Head unit, hertz 6.5’s in the fairing, JL audio 8.8’s in the lids and the 8.8’s in the lowers. It’s all being ran off two diamond 4V2 600watt amps. The one amp is wired front bridged @2ohm to the lowers, rear bridged @2ohm to the lids and the other amp is running off the front channels to the fairing speakers. Problem I’m having is all 4 of the 8.8’s have a high pitched squeal coming from the tweeters, the 6.5’s in the fairing don’t squeal at all. It’s always there with the ignition in the run position, if I switch it to acc the squeal goes away. The squeal also gets louder or quieter based on the gain adjustment. The amps are wired with 4ga power and ground direct from the battery (50a fuse about 8” from positive post), the 4ga goes into a distribution block and then 8ga out to both amps for both power and ground. I’ve tried everything I can think of but cannot get rid of the squeal. Any ideas? Sorry for the long post trying to give all the info I can
Old Jun 25, 2018 | 03:19 PM
SBates08's Avatar
SBates08
How long have you been running this setup wired like this?
Old Jun 25, 2018 | 03:23 PM
2deuceguy's Avatar
2deuceguy
bikes had about 50 miles for engine break in but stereo was off for all of that. It’s all new except the deck and 6.5’s
Old Jun 25, 2018 | 03:26 PM
2deuceguy's Avatar
2deuceguy
would you recommend wiring it a different way? This is how the shop the amps were purchased from recommended it be wired
Old Jun 25, 2018 | 03:39 PM
SBates08's Avatar
SBates08
I was just trying to look up the specs on those amps to see if they were capable of being bridged 2ohm.
Old Jun 25, 2018 | 03:50 PM
Tailwind's Avatar
Tailwind
Exactly. No can do. That amp is gonna fry.
T
Old Jun 25, 2018 | 03:56 PM
Gannicus's Avatar
Gannicus
First rule of engagement. NEVER BRIDGE AT 2 OHMS!!
Bridging should Always be at a 4 ohm load!!
Old Jun 25, 2018 | 04:08 PM
2deuceguy's Avatar
2deuceguy
T
damn I specifically asked if it would be good bridged at 2 ohms and was assured it would be. Looking through the sheets that came with the amps it was showing bridged @4ohms 300x2 but it had N/A next to bridged @2 ohms, that’s when I contacted the dealer about that. Anyway, how would you guys recommend wiring this? The rears bridged to one 8.8 per channel off the one amp then do the same for the front 8.8’s off the other amp and run the 6.5’s off the deck? Thanks for any help guys
Old Jun 25, 2018 | 04:48 PM
Tailwind's Avatar
Tailwind
Hate to bring bad news but I think with that setup ur gonna have to back out of those amps.
Get a stout 4 channel for the 880s and a micro for the fairing.
T
Old Jun 25, 2018 | 04:56 PM
SBates08's Avatar
SBates08
I agree with T on this. It'll take both of those amps ran in 4ohm bridged comparison to cover those 4 speakers and that's a lot of power to harness to keep from blowing those 8.8's. You can keep these if you don't get carried away and try to over drive them but you'll still need a Micro 4ch to push the fairing.
