Not satisfied
So I won't dispute the 8 ohm vs 4 ohm thing, because honestly I don't know enough about it. I'm just trying to figure out why you'd use 1 amp for each speaker when you could probably get the same wattage to each by paralleling them down to 4 with one amp. Unless I'm totally misunderstanding this whole thing from the get go. I'm not here to bash anyone or question their credibility. I'm just trying to figure this out in my pea brain. This watts stuff may sound like nonsense, but it's not. Too little, you don't get the right sound. Too much, you don't get the right sound. Again, just trying to look at this from average joe perspective who doesn't have the means to drop over a grand on a fairing setup.
In the spirit of the 4th of July and the birth of this great country, I welcome Louie and his expertise and knowledge with a fresh start to this great forum! Have a great 4th of July Lucky Seven!!
I’m not familiar with this speaker but the listing said designed to be used with a xover. Then it must have separate feeds for the woofer and driver? If that’s the case, the woofers could be parallel on one amp, drivers on other. That would make a 4 ohm load and could be tuned separate. Am I close or a complete idiot?
The setup suggested does not involve running one of the 600.1 amps for the horns... just to avoid confusion lol
We used 2 ohm.
Several have asked, whats in the 2018 Road Glide in my sig pic...
2 Beyma 8 proCX in the front fairing SounDigital 600x1 running each one
4 Beyma 6.5 GMND in the tourpack. Soundigital 1200x4 running the 4 in the pack
1 Beyma 6.5 GMND, and one Beyma 6" Horn in Each Lid SounDigital 800x4 Running those
1 DD 500 Series Sub in each bag. SounDigital 600x1 Running each one of those
Ground Zero DSP..
All Amps and Processor in front fairing.
Ground Zero DSP..
We used 2 ohm.
Ground Zero DSP..
Ground Zero DSP..
There is alot of stuff that can be cut out to make room. I will post some pics tomorrow.
