Need 6.5 component recommendations
Old Jul 8, 2018 | 04:05 AM
Gannicus's Avatar
Gannicus
Now in regard to both of those speakers. I can tell you this. The Kappa's sound better with the Cerwin Vega B52 amp. So if you go that route, I'd recommend the CV amp.
Don't know how reliable the Hertz ECX speakers are but they sounded damn good with the NVX amp. The CV/Kappa combo is a tried and true forum set up but if the Hertz speakers prove to be reliable. That set up sounds just as good.
Old Jul 8, 2018 | 08:40 AM
vondoom88's Avatar
vondoom88
Thanks for the links. Those are the exact ones I tried linking to.
Not sure if I want to bridge the amp as I might add lowers to the bike to extend my riding season. Living in Northern Illinois doesn't exactly have any perks at all. Not sure why I stay honestly.
Anyway would that NVX still drive those Hertz good enough without being bridged?
Old Jul 8, 2018 | 10:49 AM
vondoom88's Avatar
vondoom88
Default Here's a pic of her
04
Old Jul 8, 2018 | 10:50 AM
vondoom88's Avatar
vondoom88
Old Jul 8, 2018 | 11:25 AM
Gannicus's Avatar
Gannicus
No Sir. Not enough amp. Even if you ran em on one channel in parallel. Each speaker would only receive 50 watts @ 2 ohms. Not enough power. You need those speakers to receive at the very least 100 watts @ 4 ohms. The 2 ohm Kappa's would receive 100 watts each but I can tell you from experience those kappa's need way more power than 100 watts to sound good. If you're gonna run lowers I'd take a look at the Soundstream PN4.1000D on that bike. Plenty power for anything you want to do. The NVX is a great performer bridged or if you wanted to run tweets or Horns but your 6.5 speakers are going to need more power.
Old Jul 8, 2018 | 11:33 AM
vondoom88's Avatar
vondoom88
Well I pulled the trigger on the nvx amp & the hertz ECX's so hopefully in a week or two i'll have them installed and jamming
Old Jul 8, 2018 | 11:34 AM
vondoom88's Avatar
vondoom88
I'll run her bridged then
Old Jul 8, 2018 | 11:38 AM
Gannicus's Avatar
Gannicus
You'll like that set up. For a two speaker system. It rocks!!
Old Jul 8, 2018 | 11:44 AM
vondoom88's Avatar
vondoom88
Just curious could I fit two of those NVX amps in the fairing? If I decided to go with speakers in the lowers as well
Old Jul 8, 2018 | 12:27 PM
Dsm Limited's Avatar
Dsm Limited
I'm sure you can. Those amps are very small. You could put one in your back pocket if you don't wear skinny jeans.lol
