Need to update stereo.......
Old Jul 8, 2018 | 06:25 AM
1badbagger's Avatar
1badbagger
Default Need to update stereo.......
Wow, I haven't been on here in almost 2 years !!!
I have a 2003 FLHTC and the Sony stereo is about to die, the volume **** is ions. I have NO IDEA what unit will match up with the factory wiring/plug like the Sony did. It's just got 2 speakers in the dash, none in the rear.
Only requirement besides plug-n-play is that it has blue tooth.
Any suggestions?
Old Jul 8, 2018 | 07:21 AM
WVJarhead's Avatar
WVJarhead
Check out Aquatic AV. They have two models that are direct plug and play with Harley and have blue tooth as well.
https://www.aquaticav.com/harley/
Old Jul 8, 2018 | 09:57 AM
kylebryan's Avatar
kylebryan
I'm happy with my Aquatic AV head unit. Only concern is it's a little hard to see in the sun.
Old Jul 8, 2018 | 12:40 PM
Matty_d's Avatar
Matty_d
Just get another Sony and swap it out. No need to fork out the $$$ for an Aquatic.
Old Jul 8, 2018 | 01:35 PM
1badbagger's Avatar
1badbagger
Yep, I found the Aquatic right after I posted this. I'll be getting the $300.00 job.
Changing to the Aquatic is no more difficult than putting in another Sony.
Thanks all.
Old Jul 8, 2018 | 01:48 PM
1badbagger's Avatar
1badbagger
I installed the Sony 13 years ago. I'm hoping it used the Harley factory mount, I don't remember, and this Aquatic uses the factory mount. I hope the Sony used the factory mount, guess I'll find out as I'm about to order the unit today.
Old Jul 11, 2018 | 08:57 PM
1badbagger's Avatar
1badbagger
The Aquatics arrived today and installed it in an hour total. Easy as you;d be. Easier than the Hogtunes install years ago and sounds good.
Thanks for the heads up.
Old Jul 12, 2018 | 06:13 AM
WVJarhead's Avatar
WVJarhead
Glad it worked out brother. Enjoy!
Old Jul 13, 2018 | 03:50 PM
1badbagger's Avatar
1badbagger
Well, it sounded good, UNTIL I went out for a ride today. If I turn it up past 27 or so it sounds terrible, breaking up and fading in and out with both fm and bluetooth. Not a happy camper, I'll go do some research and see what I can find. I read of a few others having this problem but I didn't read their entire posts.
Have Hogtunes speakers.......
Old Jul 13, 2018 | 09:29 PM
Biggzed's Avatar
Biggzed
Is there an amp in the system? What EQ options does the stereo have? Sounds like you may need to just tweak some settings? Have you tried turning the bass way down on the stereo? In my experience trying to get any bass sound out of inexpensive speakers make them sound similar to how your describing.
Zach
