Sena Audio Quality
I always thought the music audio quality sucked. But, I assumed that with something as well reviewed as the Sena it must be something in my set up.
But. Alas...today I ran across someone with the same headset, and he asked how I liked the audio quality. We both agreed the music sounded like a 1960’s era 3 transistor radio. Whereas the Harley Boom direct connect sounds significantly better.
Whats up? What do you all think of the Sena Bluetooth audio quality?
I play my MP3 playlist on my Zumo navigation unit, via Bluetooth to my Sena headset. The Sena supports 2 active Bluetooth channels, I also link my iPhone to the Sena. What I have discovered is the the Sena acts like it has a high fidelity channel and a low fidelity channel...or maybe one is just screwed up. Anyhow...if I follow the following activation sequence, it always links to the high fidelity channel, and I get much better and acceptable audio quality playing from my Zumo to my Sena, I Stumbled into this accidentally, and it took me a while to replicate it.
- Sena turned off
- IPhone on with blue tooth enabled
- turn on Zumo
- move to the audio play menu on the Zumo, and select the song you want to start playing...but don’t press play.
- turn in the Sena headset,
- after all the beeping in the Sena stops, press ignore on the Zumo if a “Bluetooth device disconnected” message comes up on the Zumo.
- press play on the Zumo..
any variation to the above yielded inconsistent results.
oh yeah, I wish the Sena had a power on indicator.
Edit: I can’t tried syncing up the Zumo to the Sena without first linking the iPhone. I’ll have to give that a try after my Sena recharges...
