Thanks. I wondered after looking at the specs. Not sure the ferrites will fit either and don't want to spend $$$$ for those if they don't fit in the fairing.
Haze what are your thoughts on these in some lowers on a road king?
You will have to significantly modify stock lowers to get these to fit....they are VERY deep. What would work out great is a set of Voo Doo lowers with a set of the 8 inch version of these.
What Beyma 6.5 woofer is similar to what is in the Coax? I have PRV Neos and ST25s. Thinking about swapping out the PRVs for Beyma. Or would I be better off with the Beyma coax and tune both sets of horns? Diamond HXM 800.4 on the woofers and a Diamond micro on the horns. DSI-2 DSP
Thx
Thx
CG, what kinda bike? The compression driver on that coax is louder and plays lower in the vocal range than an ST25. I’d swap it all out with the amp wiring you have. How many woofers is that diamond 4 pushing.
18 Road Glide- The 800.4 is on the PRVs in the fairing and PRV 250 comp drivers inside each bag. In the Twisted 8 lids I have Beyma 8P300Fe/N and ST35s Lower rear bags I have Beyma CX300Nd/Ns. A Diamond HXM 800.2 in each bag. The 8s in each bag are wired parallel and the 800.2s are bridged. Still trying to pet the Unicorn.
Thx
